Arctic Cooling Freezer 7 Pro Rev.2 CPU Cooler (Intel & AMD Compatibility)
Quicklinx: 73WGWS00 Mfr#: DCACO-FP701-CSA01
High Performance CPU Cooler for Intel and AMD
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users
ARCTIC Freezer 7 PRO Rev. 2 - 150W CPU Cooler for Intel socket 1366 / 1156 / 1155 / 1150 / 775 + AMD socket FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2 / 939
Main features
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Extremely Cool
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amounts of heat faster and more efficiently. Featuring a 92mm PWM fan, 6 heatpipes and pre-applied ARCTIC MX-2,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity - becoming one of the most efficient CPU coolers for power users.
Extremely Quiet
The Freezer 7 Pro Rev.2 is extremely quiet. Thanks to the low noise impeller and patented fan holder, the 92mm fan is almost inaudible. Controlled by PWM signal, the fan runs just the necessary speed for lowest noise level at maximum cooling capacity. The Freezer 7 Pro Rev.2 generates only 0.8 Sone at 2,500rpm which is much quieter than standard coolers.
Easy Installation
The unique mounting system is very user-friendly. The whole installation can be done in a few minutes. This is a total peace of mind solution for both Intel and AMD users
Heat Sink Dimensions (L x W x H)
104mm x 58mm x 126.5mm
Fan Size
92mm
Fan Speed
900 - 2500 rpm (controlled by PWM)
Air Flow
45 CFM / 77 m3/h
Max. Cooling Capacity
130 Watts
Bearing Type
Fluid Dynamic Bearing
520g
Warranty
72 months
