Freezer 13 carries on the legacy of the renowned Freezer 7 Pro Rev.2 to continue providing efficient and low noise CPU cooling solution for enthusiasts. Featuring four U-shaped high performance heatpipes and 45 efficiently formed aluminum fins; the Freezer 13 is able to dissipate massive heat that is produced in high-end CPUs, such as Intel Core i7.
ARCTIC Freezer 13 - 200W CPU Cooler for Intel socket 1366 / 1156 / 1155 / 1150 / 775 + AMD socket FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2 / 939 / 754
- ARCTIC Freezer 13 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket, Socket AM1, LGA1151 Socket, Socket AM4, LGA2066 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Bearing
- Fluid dynamic bearing
- Rotation Speed
- 600-2000 rpm
- Air Flow
- 36.4 cfm
- Heat pipe technology, Pulse-width modulation (PWM) support
- 695 g
- 6-year warranty
- Product Type
- Processor cooler
- 695 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Aluminium
- Heatsink Dimensions
- 130 mm x 123 mm x 96 mm
- Fan Diameter
- 92 mm
- Fan Bearing
- Rotation Speed
- 600-2000 rpm
- Air Flow
- 36.4 cfm
- Limited warranty: - 6 years
