Arctic Cooling Freezer 13 CO High Performance CPU Cooler for Intel and AMD
Quicklinx: 7NWRWS00 Mfr#: UCACO-FZ13100-BL
Dedicated to operate 24 hours a day, 7 days per week, the Freezer 13 CO delivers superior cooling performance with utmost durability. Employing a Japanese dual ball bearing, the fan operates with reduced friction and hence its lifespan is substantially extended. Freezer 13 CO is your ultimate cooler to maintain your computer systems under optimal temperature at all times.
Continuous Operation
"CO" stands for Continuous Operation and makes the cooler suitable for PCs with non-stop operation like servers. This feature is brought by the dual ball bearing used in the fan, which reduces rotational friction, i.e. is significantly less sensitive to dust and high temperature and hence is up to 5 times more durable than generic or modified bearings.
The included fiber reinforced retention module offers long-lasting support for the CPU cooler's weight throughout its lifetime.
Superior Cooling Performance
Utilizing a 92 mm PWM fan spinning up to 2,000 RPM, the Freezer 13 CO brings maximum cooling capacity of 200 Watts to ensure your CPU stays cool at all times. In addition, four double-sided 6 mm copper heatpipes and a 45-fin heatsink ensure efficient heat dissipation.
Quick Installation
The unique mounting system does not require disassembly of the motherboard, making the installation quick and easy, at the same time guaranteeing excellent stability and full transport proofness. Pre-applied ARCTIC MX-4 thermal compound facilitates the whole installation process further.
  • Continuous operation
    This feature is brought by the dual ball bearing used in the fan, which reduces rotational friction, i.e. is significantly less sensitive to dust and high temperature.
  • Superior cooling performance
    Utilizing a PWM fan, the Freezer 13 CO brings maximum cooling capacity of 200 watts to ensure your CPU stays cool at all times. In addition, four double-sided copper heat-pipes and a heat-sink ensure efficient heat dissipation.
  • Quick installation
ARCTIC Freezer 13 CO - processor cooler
Processor cooler
Compatibility
Socket 754, LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
600-2000 rpm
Air Flow
36.4 cfm
Heat pipe technology, Pulse-width modulation (PWM) support
12.3 cm x 9.6 cm x 13 cm
0.71 kg
6-year warranty
Processor cooler
12.3 cm
9.6 cm
13 cm
0.71 kg
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Bearing
Dual ball bearing
Rotation Speed
600-2000 rpm
Air Flow
36.4 cfm
Limited warranty: - 6 years
