The Alpine 11 Pro is for users who look for an extremely quiet, high performance and easy-to-install cooling solution.
The Alpine 11 Pro features a more sophisticated acoustic design than the stock cooler. Thanks to the patented vibration absorption and fan holder, the cooler is barely audible - only 0.4 Sone at 2,000 rpm - a standard that the stock cooler cannot compete. With a 92mm PWM fan and a bigger heatsink design, the maximum cooling capacity of the Alpine 11 Pro achieves 95 watts.
Moreover, the unique mounting system is very user-friendly and provides an absolutely transport safe solution. The cooler is fastened by screws, no back plate is necessary nor has the mainboard to be disassembled. The whole installation can be done in less than a minute. This is a totally peace of mind solution for Intel users.
ARCTIC Alpine 11 Pro Rev.2 - 95W CPU Cooler for Intel socket 1156 / 1155 / 1150 / 775
- ARCTIC Alpine 11 Pro Rev. 2 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, LGA1155 Socket, LGA1150 Socket, LGA1151 Socket
- Fan Diameter
- 92 mm
- Fan Height
- 85 mm
- Rotation Speed
- 500-2000 rpm
- Air Flow
- 36.7 cfm
- Pulse-width modulation (PWM) support
- 11.3 cm x 10.5 cm x 8.5 cm
- 428 g
- Anti-vibration
- 6-year warranty
- Product Type
- Processor cooler
- 11.3 cm
- 10.5 cm
- 8.5 cm
- 428 g
Heatsink & Fan
- Compatible With
- Fan Diameter
- 92 mm
- Fan Height
- 85 mm
- Rotation Speed
- 500-2000 rpm
- Air Flow
- 36.7 cfm
- Anti-vibration
- Limited warranty: - 6 years
