The perfect size to share your android experience
The ARCHOS 101 G9 is the perfect entertainment tablet to share the Android Honeycomb experience. With 16GB of storage space, full 1080p HD to watch movies on the 10.1" wide 1280 x 800 16:10 screen. Plus thanks to its powerful dual-core ARM Cortex A9 processor, the ARCHOS 101 G9 browses the web up to 50% faster than standard NvidiaTegra 2TM tablet. Because you shouldn't be forced to choose between a 3G and a WiFi tablet at purchase, ARCHOS developed the ARCHOS G9 3G stick; a patented solution letting you add a 3G stick to your ARCHOS G9 tablet whenever you feel like.
Key Features:
- Android 3.2 Honeycomb powered with Google's suite of Android Applications
- Ultra-fast thanks to an ARM Cortex dual-core A9 processor running up to 1.5 GHz
- ARCHOS developed multimedia applications with greater format support and improved interface
- Android in High Definition on your TV
- Available in 8GB or 16GB flash model and Hard Drive model with 250GB of storage
- 3G Ready with ARCHOS 3G stick solution for both laptops and G9 tablets. ARCHOS 3G stick sold separately - QuickLinx code 809D
Making 3G an option
Because you shouldn't be forced to choose between a 3G and a Wi-Fi tablet at purchase, ARCHOS have developed the ARCHOS G9 3G stick; a patented solution letting you add a 3G module to your ARCHOS G9 tablet whenever you feel like. -
Standard PC 3G stick
Though designed with ARCHOS G9 tablets in mind, the ARCHOS G9 3G stick is fully compatible with any Mac or Windows PC. With a simple Plug and Surf interface thanks to the onboard drivers, you can share your G9 3G stick between your devices using just one data plan. -
Designed to fit perfectly into G9 tablets
The ARCHOS G9 3G stick has been specially designed to fit perfectly into the back of any G9 tablet. Just remove the cover and slide in the G9 3G stick. With no protrusions once it's inserted, it's immediately detected by your tablet, unleashing the full portability of your ARCHOS G9 tablet. -
Flash for portability
ARCHOS' G9 tablets with hard drive storage are only 3 mm thicker than their flash counterparts. And with the flash version weighing only 450 g your tablet truly is portable. -
Android market
ARCHOS G9 tablets will include access to Android Market. With over 200 thousand applications available to download, whether you're after games, news, tools or widgets to personalize your Honeycomb experience, there are plenty of apps to make your ARCHOS G9 tablet your own. -
Preinstalled apps to get you started
To help you get started ARCHOS preinstall some of the best and most useful Android applications onto G9 tablets. Picsel Office Suite lets you turn your G9 tablet into a tool for work, Brief Me brings all your facebook, twitter and news feeds all in one place with a home screen widget and Evernote is the perfect aid to daily life with cloud note taking. -
Stream over your home Wi-Fi network
Streaming media from your PC or Mac is included as standard in the ARCHOS multimedia apps. Using UPnP and Samba protocols, streaming or downloading music and video from your computer to your ARCHOS G9 tablet is easy and available directly within the ARCHOS multimedia apps. -
Metadata fetching
ARCHOS multimedia apps give you the option to browse your music and videos either directly in your folder structure or from the automatically organized multimedia libraries. With film and TV series metadata automatically downloaded, even your video files are automatically organized by title, actor, director, year, season, and episode. -
Android on TV (HDMI out)
Thanks to the mini-HDMI port on the ARCHOS G9 tablets you can quickly and easily plug your G9 tablet into your HDTV. With full screen mirroring, you can take your Android experience to the big screen to share with friends or family.
- Archos 101 G9 - tablet - Android 3.2 (Honeycomb) - 16 GB - 10.1"
- Product Type
- Tablet
- Operating System
- Display
- 10.1" TFT - 1280 x 800
- Processor
- ARM OMAP 4 (Dual-Core)
- Processor Clock Speed
- 1.2 GHz
- Storage
- 16 GB
- Supported Flash Memory Cards
- microSD, microSDHC
- Wireless Connectivity
- 802.11b/g/n, Bluetooth 2.1 EDR
- Navigation System
- GPS
- HDMI Port
- 27.6 cm x 1.3 cm x 16.7 cm
- 0.65 kg
- Product Type
- Tablet
- Operating System
Display
- 10.1" TFT
- Resolution
- 1280 x 800
- Processor
- ARM OMAP 4
- 1.2 GHz
- Number of Cores
- Dual-Core
- Storage
- 16 GB
Communications
Navigation System
- Receiver
- GPS
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, MP3, FLAC, AAC +, OGG
- Supported Digital Video Standards
- MPEG-4, H.264, MPEG-4 ASP
- Audio
- Microphone, speaker
System Requirements for PC Connection
- OS Required
- Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Expansion and Connectivity
- 2 x USB 2.0 , 1 x HDMI
- HDMI Port
- Technology
- Lithium polymer
- Run Time Details
- Audio playback: up to 36 hour(s) , Video playback: up to 7 hour(s)
- Sensors
- Digital compass, G-sensor
- Built-in leg stand, G-sensor
- Included Accessories
- Power adapter
- 27.6 cm
- 1.3 cm
- 16.7 cm
- 0.65 kg
