Apple World Travel Adapter Kit
Quicklinx: B5HCWS00 Mfr#: MD837ZM/A
Device Type: iPad Mini, Macbook, iPad, iPad Air + 2 more
Type: Cable
Device Screen Size: [N/A]
Colour: [N/A]
£20.20 ex VAT
£24.24 inc VAT
The World Travel Adapter Kit includes a set of seven AC plugs with prongs that fit different electrical outlets around the world, each laser-etched with the regions they are compatible with. For world travelers, this is the perfect kit to ensure power connectivity in most countries you may travel to. The kit is designed to work with iPod, iPhone, and iPad, and is compatible with Apple MagSafe and MagSafe 2 Power Adapters (for MacBook, MacBook Pro, and MacBook Air), 10W and 12W USB Power Adapters, and Portable Power Adapters. The AC plugs included in the World Travel Adapter Kit directly support outlets in North America, Japan, China, United Kingdom, Continental Europe, Korea, Australia, Hong Kong, and Brazil.
Apple World Travel Adapter Kit - power connector adapter kit
Power connector adapter kit
Australia, China, Japan, Hong Kong, Korea, North America, Continental Europe, Brazil, United Kingdom
MacBook (Early 2015, Early 2016, Mid 2017); MacBook Air (Late 2018, Mid 2019), with Retina display (Early 2020, Late 2018, Mid 2019); MacBook Pro (Late 2016, Late 2019, Mid 2017, Mid 2018, Mid 2019)
Cable Kit Details
7 x power connector adaptor
Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Late 2018, Mid 2019), with Retina display (Early 2020, Late 2018, Mid 2019) , Apple MacBook Pro (Late 2016, Late 2019, Mid 2017, Mid 2018, Mid 2019)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: B5HC 048265
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £7.17
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Device Type: Macbook
Device Type: iPad
Device Type: iPad Air
Device Type: iPad Air 2
Device Type: iPod
Type: Cable
Colour: [N/A]
Brand: Apple
Stock Status: Used Stock
