With the Wireless Charging Case, charging your earbuds is simple. The LED indicator on the front of the case lets you know that your earbuds are charging. And when you're away from a charging mat, you can use the Lightning port to charge.
- Apple Wireless Charging Case charging case
- Product Type
- Charging case
- Designed For
- Headphones
- 4.43 cm x 2.13 cm x 5.35 cm
- 40 g
- Wireless Charging
- Wireless Charging Standards
- Qi
- Designed For
- AirPods (1st generation, 2nd generation)
- Product Type
- Charging case
- Designed For
- Headphones
- 4.43 cm
- 2.13 cm
- 5.35 cm
- 40 g
- Input Connectors
- Apple Lightning
- Input Connectors Qty
- 1
- Wireless Charging
- Qi
- LED indicator
- Designed For
- Apple AirPods (1st generation, 2nd generation)
