Apple Watch Series 8 GPS + Cellular 41mm Graphite Stainless Steel Case with Graphite Milanese Loop
Quicklinx: GZNCWS00 Mfr#: MNJM3B/A
Your essential companion is even more powerful. Introducing temperature sensing for deeper insights into women's health. Crash Detection to get help in an emergency. Sleep stages to better understand your sleep. The future of health never looked so good.
Smooth and seamless
Apple Watch Series 8 features a big, brilliant Always-On display. Narrow borders push the screen right to the edge, resulting in an elegant integration with the curvature of the case.
Always-On Retina display
Take it all in. Get it all done. The bright Always-On screen makes detailed watch faces look stunning and easy to read, even when your wrist is down. The large display accommodates all your favorite complications and makes tapping, typing, and swiping a snap.
Tougher than tough
The same innovations used to create the beautiful, edge-to-edge Always-On display also help make it incredibly durable. A thick front crystal, robust geometry, and flat base make it resistant to cracking.
Advanced health sensors
The more informed you are about your health, the more empowered you are to affect it. Advanced health sensors in Apple Watch Series 8 provide insights to help you better understand your health.
Understand your cycle like never before
Apple Watch Series 8 has an innovative sensor that tracks your temperature while you sleep, so you can see changes over time. Cycle Tracking uses this data to provide a retrospective estimate of when you likely ovulated, which can be helpful for family planning. When combined with your heart rate and logged cycle data, you'll get a detailed view of your menstrual cycle.
Period predictions
Get improved period predictions with wrist temperature data. You can receive notifications if your logged cycle data shows a possible cycle deviation, like irregular or prolonged periods. You can share your cycle history with your healthcare provider for more informed conversations.
Crash Detection
Apple Watch Series 8 is able to detect if you're in a severe car crash. When a crash is detected, Crash Detection can automatically connect you with emergency services, provide dispatchers with your location, and notify your emergency contacts. Crash Detection uses the combined power of an improved 3-axis gyroscope and a g-force accelerometer that has the higher dynamic range. It also uses a microphone, barometer, GPS, and an advanced sensor-fusion algorithm trained on over 1 million hours of real-world driving and crash data to detect if you're in a severe crash.
Low Power Mode
You've got extra time on your hands. Get even more hours with the Low Power Mode. Great for occasions when you're away from your charger, like a long flight.
  • Smooth and seamless
  • Always-On Retina display
  • Tougher than tough
  • Advanced health sensors
  • Understand your cycle like never before
  • Period predictions
  • Crash Detection
  • Low Power Mode
Apple Watch Series 8 (GPS + Cellular) - graphite stainless steel - smart watch with milanese loop - graphite - 32 GB
Smart watch
Manufacturer Model Number
A2773
Tracking Data
Distance, time, calories burned, activity, sleep activity, heart rate, blood oxygen saturation, ECG, menstrual cycle, ovulation phase, sleep stages, rapid eye movement (REM)
Wi-Fi, Bluetooth, LTE, UWB 4G
Navigation
GPS/GLONASS/Galileo/BeiDou/QZSS receiver
Display
Retina LTPO OLED 352 x 430 pixels - sapphire glass - always-on display
Apple S8 SiP
Storage
32 GB
Operating System
WatchOS
Case
Rectangular - 41 mm - stainless steel
Band
Graphite - milanese loop - stainless steel - changeable
Payment Technology
Apple Pay
Intelligent Assistant
Siri
Input
Touch screen
Fits Wrist with Circumference
130-180 mm
Notifications
High and low heart rate, irregular rhythm, cardio fitness, calendar, SMS, Email
Fall detection, Crash Detection, International Emergency Calling, Emergency SOS, brightness: 1000 nits, Edge-to-edge display, Compass Waypoint, Family Setup support, noise monitoring, call handling
Supported Host Device OS
iOS
Rechargeable Lithium Ion
Battery Run Time
Up to 18 hours
35 mm x 10.7 mm x 41 mm
42.3 g
0.31 W/kg (head) , 0.55 W/kg (limb)
1-year warranty
Smart watch
A2773
iOS 16 or later
Notifications
Navigation
Tracking Data
Payment Technology
Apple Pay
Audio Input
Microphone
Audio Output
Speaker
Operating System
WatchOS
Wearing Style
Watch style
Feedback Type
Audio alert, vibration alert, visual interface
Clock Display
Set Goals
Sensors
Accelerometer, gyroscope, temperature sensing, electrical heart sensor, digital compass, always-on altimeter, optical heart sensor (3d gen), ambient light sensor, blood oxygen sensor
Cellular
WCDMA (UMTS)
Mobile Broadband Generation
4G
Service Provider
Not specified
SIM Card Type
Electronic SIM card (e-SIM)
Storage
32 GB
Display
Retina LTPO OLED - colour
Resolution
352 x 430 pixels
Protection
Sapphire glass
Always On Display (AOD)
3G UMTS Band
Band 1, Band 2, Band 5, Band 8, Band 10
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 39, Band 40, Band 41, Band 66
Wireless Interface
IEEE 802.11b/g/n, Bluetooth 5.0, LTE, Ultra-Wideband (UWB)
Input Device
Touch sensitive screen
CPU
Manufacturer
Apple
S8 SiP
U1 chip, W3 Apple wireless chip
Lithium Ion
Rechargeable Battery
Wireless Charging
Run Time (Up To)
18 hours
Smart Watch Case
Case Shape
Rectangular
Case Size
41 mm
Crown Type
Digital with haptic feedback
Case Back
Sapphire crystal and ceramic back
Case Details
Graphite stainless steel
Band
Name
Milanese loop
Changeable
130-180 mm
Clasp Type
Magnetic closure
Material
Woven stainless steel mesh
Graphite
Details
Case only: 42.3 g
Internet of Things (IoT)
Siri
Voice Controlled
Direct
Preloaded Software
Apple Pay, GymKit
Vibrating Alert
Body Material
Stainless steel
Protection
Water-resistant, dust-resistant, crack-resistant
IP6X
Magnetic fast charger to USB-C cable (1 m)
Warranty
1-year warranty
Max Depth of Water Resistance
50 m
