Answer a call from your surfboard. Stream your favorite songs on your run. And do it all while leaving your phone behind. The Apple Watch Series 3 gives you the freedom to go with just your watch.
The watch reimagined
It delivers important information when and where you need it. Helps you easily perform everyday tasks in seconds. Instantly connects you to the people and things you care about most. All while keeping precise time. -
You'll know it when you feel it
Because this smartwatch sits on your wrist, it can give you a gentle tap the instant you receive an alert. -
Stay in touch like never before
You won't just send and receive messages, calls, and mail more easily and efficiently. You'll express yourself in unique, fun, and more personal ways. Communicating with the smartphone is discreet, sophisticated, and nuanced - a different way to connect with others. -
Messages, calls, and mail designed for your wrist
The ways you communicate on your smartphone are even more immediate on the smartwatch. To read a message or email, just raise your wrist. You can take a quick phone call using the built-in speaker and microphone. -
Easy ways to respond
You don't always have time to craft a lengthy response to a message or email. With the smartwatch, you can make a quick but meaningful reply. -
Say it with feeling
You don't even have to use words. The Digital Touch feature gives you fun, spontaneous ways to connect with other smartwatch wearers, wrist to wrist. -
Sensitive enough to tell a tap from a press
In addition to recognising touch, the smartwatch senses force, adding a different dimension to the user interface. With Force Touch, pressing firmly on the display brings up additional controls in apps. -
Technology with a more human touch
This linear actuator inside the smartwatch taps you on the wrist when you receive a notification, press down on the display, or use Digital Touch. The Taptic Engine gives different kinds of notifications and actions their own distinct character. So even with the accompanying audio cues turned off, you can feel the difference between an alarm and an incoming phone call without even looking.
- Apple Watch Series 3 (GPS + Cellular) - stainless steel - smart watch with sport band - soft white - 16 GB
- Product Type
- Smart watch
- Tracking Data
- Distance, time, calories burned, activity, heart rate, steps taken
- Connectivity
- Wi-Fi, Bluetooth 4G
- Navigation
- GPS/GLONASS/Galileo/QZSS receiver
- Display
- OLED 272 x 340 pixels - sapphire glass
- Processor
- Apple S3
- Storage
- 16 GB
- Operating System
- WatchOS 4
- Case
- 38 mm - stainless steel
- Band
- Soft white - sport band - fluoroelastomer
- Intelligent Assistant
- Siri
- Input
- Force Touch
- Fits Wrist with Circumference
- 130-200 mm
- Notifications
- Calendar, SMS, Email
- Call handling, music remote handling, camera remote control, listening to music, Retina Display technology, text messages handling
- Supported Host Device OS
- iOS
- Battery
- Lithium Ion
- Battery Run Time
- Up to 18 hours
- 33.3 mm x 11.4 mm x 38.6 mm
- 42.4 g
- Specific Absorption Rate (SAR)
- 0.14 W/kg (head) , 0.15 W/kg (limb)
- Product Type
- Smart watch
- iOS 11 or later
- Supported Mobile Messaging Services
- SMS
- Notifications
- Messaging Services
- SMS
- Navigation
- Tracking Data
- Audio Input
- Microphone
- Audio Output
- Speaker
- Operating System
- WatchOS 4
- Wearing Style
- Watch style
- Clock Display
- Set Goals
- Sensors
- Accelerometer, ambient light sensor, gyro sensor, heart rate, barometric altimeter
Cellular
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- SIM Card Type
- Electronic SIM card (e-SIM)
Storage
- Capacity
- 16 GB
Display
- OLED - colour
- Resolution
- 272 x 340 pixels
- Protection
- Sapphire glass
- Wireless Interface
- IEEE 802.11b/g/n, Bluetooth 4.2
Input Device
- Touch sensitive screen (Force Touch)
CPU
- Manufacturer
- Apple
- S3
- W2 Apple wireless chip
- Technology
- Lithium Ion
- Run Time (Up To)
- 18 hours
Smart Watch Case
- Case Size
- 38 mm
- Crown Type
- Digital
- Case Back
- Ceramic back
- Case Details
- Stainless steel
Band
- Name
- Sport band
- 130-200 mm
- Clasp Type
- Pin-and-tuck
- Material
- Fluoroelastomer
- Soft white
- 33.3 mm
- 11.4 mm
- 38.6 mm
- 42.4 g
Internet of Things (IoT)
- Siri
- Preloaded Software
- Siri
- Vibrating Alert
- Body Material
- Stainless steel
- Protection
- Waterproof
- Included Accessories
- Power adapter, magnetic charging cable
- Max Depth of Water Resistance
- 50 m
