To wear it is to love it. Receive and respond to notifications in an instant. Track your daily activity. Control your music using only your voice. Pay for groceries just like that. With this smartwatch, important information and essential features are always just a raise of the wrist away. Not to mention music, maps, and phone calls, smart watch lets you do the things you do every day, more easily and conveniently. As well as lots of things that simply weren't possible before. What you put on says a lot about you. And everyone is different. So the smartwatch was designed to reflect a wide range of tastes and styles. And you can make it even more personal, to suit the occasion or your mood, by switching bands and changing watch faces. Anytime you want.
The watch reimagined
It delivers important information when and where you need it. Helps you easily perform everyday tasks in seconds. Instantly connects you to the people and things you care about most. All while keeping precise time. -
You'll know it when you feel it
Because this smartwatch sits on your wrist, it can give you a gentle tap the instant you receive an alert. -
Stay in touch like never before
You won't just send and receive messages, calls, and mail more easily and efficiently. You'll express yourself in unique, fun, and more personal ways. Communicating with the smartphone is discreet, sophisticated, and nuanced - a different way to connect with others. -
Messages, calls, and mail designed for your wrist
The ways you communicate on your smartphone are even more immediate on the smartwatch. To read a message or email, just raise your wrist. You can take a quick phone call using the built-in speaker and microphone. -
Easy ways to respond
You don't always have time to craft a lengthy response to a message or email. With the smartwatch, you can make a quick but meaningful reply. -
Say it with feeling
You don't even have to use words. The Digital Touch feature gives you fun, spontaneous ways to connect with other smartwatch wearers, wrist to wrist. -
Sensitive enough to tell a tap from a press
In addition to recognising touch, the smartwatch senses force, adding a different dimension to the user interface. With Force Touch, pressing firmly on the display brings up additional controls in apps. -
Technology with a more human touch
This linear actuator inside the smartwatch taps you on the wrist when you receive a notification, press down on the display, or use Digital Touch. The Taptic Engine gives different kinds of notifications and actions their own distinct character. So even with the accompanying audio cues turned off, you can feel the difference between an alarm and an incoming phone call without even looking.
- Apple Watch Series 2 - gold aluminium - smart watch with sport band - midnight blue
- Product Type
- Smart watch
- Tracking Data
- Distance, time, calories burned, activity, heart rate, steps taken
- Connectivity
- Wi-Fi, Bluetooth
- Display
- OLED 312 x 390 pixels - Ion-X glass
- Processor
- Apple S2
- Operating System
- WatchOS 3
- Case
- 42 mm - aluminium
- Band
- Midnight blue - sport band - fluoroelastomer - size: S/M/L
- Input
- Force Touch
- Fits Wrist with Circumference
- 140-210 mm
- Notifications
- Calendar, SMS, Email
- Call handling, Retina Display technology
- Supported Host Device OS
- iOS
- Battery
- Lithium Ion
- Battery Run Time
- Up to 18 hours
- 36.4 mm x 11.4 mm x 42.5 mm
- 34.2 g
- Specific Absorption Rate (SAR)
- 0.058 W/kg (head) , 0.054 W/kg (limb)
- Product Type
- Smart watch
- iOS 10 or later
- Notifications
- Tracking Data
- Audio Input
- Microphone
- Audio Output
- Speaker
- Operating System
- WatchOS 3
- Wearing Style
- Watch style
- Clock Display
- Set Goals
- Sensors
- Accelerometer, ambient light sensor, gyro sensor, heart rate
Display
- OLED - colour
- Resolution
- 312 x 390 pixels
- Protection
- Ion-X glass
- Wireless Interface
- IEEE 802.11b/g/n, Bluetooth 4.0
Input Device
- Touch sensitive screen (Force Touch)
CPU
- Manufacturer
- Apple
- S2
- Technology
- Lithium Ion
- Run Time (Up To)
- 18 hours
Smart Watch Case
- Case Size
- 42 mm
- Crown Type
- Digital
- Case Back
- Ceramic back
- Case Details
- Gold aluminium
Band
- Name
- Sport band
- Size
- S/M/L
- 140-210 mm
- Clasp Type
- Pin-and-tuck
- Material
- Fluoroelastomer
- Midnight blue
- 36.4 mm
- 11.4 mm
- 42.5 mm
- 34.2 g
- Preloaded Software
- Siri
- Vibrating Alert
- Body Material
- Aluminium
- Protection
- Waterproof
- Included Accessories
- Power adapter, magnetic charging cable
- Max Depth of Water Resistance
- 50 m
