Apple Watch Series 10 GPS 46mm Silver Aluminium Case with Denim Sport Band - S/M
Quicklinx: HVT7WS00 Mfr#: MWWL3QA/A
Product Range: Apple Watch
Product Model: Series 10 (GPS)
27 In Stock
£357.50 ex VAT
£429.00 inc VAT
Meet Apple Watch Series 10. A bigger display with more screen area and a thinner, lighter design. Get advanced fitness and health features with Sleep Apnoea Notifications,1 plus faster charging.
  • WHY APPLE WATCH SERIES 10 — Bigger display with up to 30 per cent more screen area.2 A thinner, lighter and more comfortable design.2 Advanced health and fitness features provide invaluable insights.3 Safety features connect you to help when you need it.4 Faster charging gives you 80 per cent battery in about 30 minutes.5
  • ADVANCED HEALTH INSIGHTS — Take an ECG anytime.6 Get notifications if you have high or low heart rate or an irregular heart rhythm.7 Understand your menstrual cycle and get retrospective ovulation estimates.8 See overnight health metrics like heart rate, respiratory rate and more with the Vitals app.9 Track sleep and get notifications if signs of sleep apnoea are detected.1
  • A POWERFUL FITNESS PARTNER — Measure all the ways you move with Activity rings, which are customisable to match your lifestyle. Get advanced metrics for a range of workouts with the Workout app. Track the intensity of your workouts with training load. Use depth and water temperature sensors for your aquatic adventures. And Apple Watch comes with three months of Apple Fitness+ free.10
  • STAY CONNECTED — Send a text, take a call, listen to music and podcasts, use Siri and get notifications on the go. Apple Watch Series 10 (GPS) works with your iPhone or Wi-Fi to keep you connected.
  • INNOVATIVE SAFETY FEATURES — Fall Detection11 and Crash Detection can connect you to emergency services in the event of a hard fall or a serious car crash. Emergency SOS lets you call for help with the press of a button.4 Check In automatically notifies a loved one when you’ve arrived at a your destination.12
  • INCREDIBLE DURABILITY — Crack resistant and IP6X-certified dust resistant. With 50m water resistance.13
  • CARBON NEUTRAL — Apple Watch Series 10 is carbon neutral when paired with select straps. Learn more about Apple’s commitment to the environment at apple.com/uk/2030.
  • SIMPLY COMPATIBLE — It works seamlessly with your Apple devices and services.14 Unlock your Mac automatically. Get approximate distance and directions to your iPhone with Precision Finding on supported iPhone models.15 Pay with Apple Pay.
  • EASILY CUSTOMISABLE — With watch straps in a range of styles, materials and colours and fully customisable watch faces, you can change your watch to fit your mood or the moment.
Apple?Watch Series?10 requires iPhone?Xs or later with iOS?18 or later.
1The Sleep Apnoea Notification Feature is available on Apple Watch Series 9 and later and Ultra 2. It is intended to detect signs of moderate to severe sleep apnoea for people 18?years old or older without a diagnosis of sleep apnoea.
2Compared with previous generations.
3Features subject to change. Some features, applications and services may not be available in all regions or all languages. See?apple.com/uk/watchos/feature-availability?for complete list.
4Emergency SOS requires a cellular connection or Wi-Fi calling with an internet connection from your Apple Watch or nearby iPhone.
5Charge times are from 0–80% and 0–100% using the included Apple Watch Magnetic Fast Charger to USB-C Cable. Testing conducted by Apple in August 2024 using pre-production Apple Watch Series 10 (GPS) and Apple Watch Series 10 (GPS + Cellular), each paired with an iPhone; all devices tested with pre-release software, Apple Watch Magnetic Fast Charger to USB-C Cable (Model A2515) and Apple 20W USB-C Power Adapter (Model A2305). Fast-charge testing conducted with drained Apple Watch units. Times measured from the appearance of the Apple logo as the unit started up. Charge time varies with region, settings and environmental factors; actual results will vary.
6The ECG app is available on Apple Watch Series 4 and later (excluding Apple Watch SE) and can generate an ECG similar to a single-lead electrocardiogram. Intended for use by people 22?years?old and over.
7Irregular rhythm notification requires the latest versions of watchOS and iOS. It is not intended for use by people under 22?years old or those who have been previously diagnosed with atrial fibrillation (AF).
8The Cycle Tracking app should not be used for birth control or to diagnose a health condition.
9The Vitals app is for wellness purposes only and not for medical use.
10Offer available to new subscribers who purchase an eligible device after 7 September 2022. [Local Pricing]/month after trial. Only one offer per Apple?Account and only one offer per family if you’re part of a Family?Sharing group, regardless of the number of devices you or your family purchases. This offer is not available if you or your family have previously subscribed to Apple?Fitness+. Offer valid for three months after eligible device activation. Plan automatically renews until cancelled. Restrictions and other terms apply.
11Fall Detection updates are available on Apple Watch Series 4 and later with watchOS 8 and later.
12Check In requires watchOS 11 or later for the sender and iOS 17 or later for the recipient. Location sharing is not supported in Republic?of Korea and might be unavailable in other regions due to local laws.
13Apple Watch Series 10 has a water resistance rating of 50 metres under ISO standard 22810:2010. This means that it may be used for shallow-water activities like swimming in a pool or ocean. Apple Watch Series 10 should not be used for scuba diving, waterskiing or other activities involving high-velocity water or submersion below shallow depth. Water resistance is not a permanent condition and can diminish over time. For additional information, see support.apple.com/HT205000. Apple?Watch Series?10 is rated IP6X dust resistant.
14watchOS 11 requires an Apple Watch SE (2nd generation), any model of Apple Watch Ultra or Apple Watch Series 6 or later paired with iPhone Xs or later with iOS 18 or later.
15Requires an iPhone and Apple Watch with second-generation Ultra Wideband chip.
16Wireless service plan required for cellular service. Contact your service provider for more details. Connection may vary based on network availability. Check apple.com/uk/watch/cellular for participating network providers and eligibility. See support.apple.com/HT207578 for additional setup instructions.
  • Legal
    Apple Watch Series 10 requires iPhone Xs or later with iOS 18 or later. ¹The Sleep Apnoea Notification Feature is available on Apple Watch Series 9 and later and Ultra 2. It is intended to detect signs of moderate to severe sleep apnoea for people 18 years old or older without a diagnosis of sleep apnoea. ²Compared with previous generations. ³Features subject to change. Some features, applications and services may not be available in all regions or all languages. See apple.com/uk/watchos/feature-availability for complete list. 4Emergency SOS requires a cellular connection or Wi-Fi calling with an internet connection from your Apple Watch or nearby iPhone. 5Charge times are from 0–80% and 0–100% using the included Apple Watch Magnetic Fast Charger to USB-C Cable. Testing conducted by Apple in August 2024 using pre-production Apple Watch Series 10 (GPS) and Apple Watch Series 10 (GPS + Cellular), each paired with an iPhone; all devices tested with pre-release software, Apple Watch Magnetic Fast Charger to USB-C Cable (Model A2515) and Apple 20W USB-C Power Adapter (Model A2305). Fast-charge testing conducted with drained Apple Watch units. Times measured from the appearance of the Apple logo as the unit started up. Charge time varies with region, settings and environmental factors; actual results will vary. 6The ECG app is available on Apple Watch Series 4 and later (excluding Apple Watch SE) and can generate an ECG similar to a single-lead electrocardiogram. Intended for use by people 22 years old and over. 7Irregular rhythm notification requires the latest versions of watchOS and iOS. It is not intended for use by people under 22 years old or those who have been previously diagnosed with atrial fibrillation (AF). 8The Cycle Tracking app should not be used for birth control or to diagnose a health condition. ?The Vitals app is for wellness purposes only and not for medical use. ¹°Offer available to new subscribers who purchase an eligible device after 7 September 2022. [Local Pricing]/month after trial. Only one offer per Apple Account and only one offer per family if you’re part of a Family Sharing group, regardless of the number of devices you or your family purchases. This offer is not available if you or your family have previously subscribed to Apple Fitness+. Offer valid for three months after eligible device activation. Plan automatically renews until cancelled. Restrictions and other terms apply. ¹¹Fall Detection updates are available on Apple Watch Series 4 and later with watchOS 8 and later. ¹²Check In requires watchOS 11 or later for the sender and iOS 17 or later for the recipient. Location sharing is not supported in Republic of Korea and might be unavailable in other regions due to local laws. ¹³Apple Watch Series 10 has a water resistance rating of 50 metres under ISO standard 22810:2010. This means that it may be used for shallow-water activities like swimming in a pool or ocean. Apple Watch Series 10 should not be used for scuba diving, waterskiing or other activities involving high-velocity water or submersion below shallow depth. Water resistance is not a permanent condition and can diminish over time. For additional information, see support.apple.com/HT205000. Apple Watch Series 10 is rated IP6X dust resistant. ¹4watchOS 11 requires an Apple Watch SE (2nd generation), any model of Apple Watch Ultra or Apple Watch Series 6 or later paired with iPhone Xs or later with iOS 18 or later. ¹5Requires an iPhone and Apple Watch with second-generation Ultra Wideband chip. ¹6Wireless service plan required for cellular service. Contact your service provider for more details. Connection may vary based on network availability. Check apple.com/uk/watch/cellular for participating network providers and eligibility. See support.apple.com/HT207578 for additional setup instructions.
Apple Watch Series 10 (GPS) - silver aluminium - smart watch with sport band - denim - 64 GB
Smart watch
Manufacturer Model Number
A2999
Activity / Sport
Golf, running, swimming, ski, cycling, hiking, walking, yoga, snowboarding, strength training, elliptical, multisport, dance, stair stepping, pilates, wheelchair, high-intensity interval training (HIIT), outdoor rowing, paddling, rowing machine, cooldown, core training, tai chi, kickboxing
Tracking Data
Distance, time, calories burned, activity, sleep activity, heart rate, blood oxygen saturation, sleep stages, noise level, menstrual cycle, ECG, ovulation phase, mindfulness
Wi-Fi 4, UWB, Bluetooth
Navigation
GPS/GNSS/Galileo/BeiDou receiver
Display
Retina LTPO3 OLED 416 x 496 pixels - 326 ppi - Ion-X glass - always-on display
Apple S10 SiP
Storage
64 GB
Operating System
WatchOS 11
Case
Rectangular - 46 mm - 100% recycled aluminium
Band
Denim - sport band - fluoroelastomer - size: S/M - changeable
Payment Technology
Apple Pay
Intelligent Assistant
Siri
Input
Touch screen, side button, double tap gesture
Fits Wrist with Circumference
140-190 mm
Notifications
Calendar, SMS, Email, applications, high and low heart rate, irregular rhythm, sleep apnea notifications, backtrack
Fall detection, Emergency SOS, medication reminder, brightness: 2000 nits, Family Setup support, International Emergency Calling, Crash Detection, noise monitoring, fast charge
Supported Host Device OS
iOS
Rechargeable Lithium Ion
Battery Run Time
Up to 18 hours
39 mm x 9.7 mm x 46 mm
36.4 g
Carbon Footprint
0 kg carbon emissions
0.17 W/kg (head) , 0.16 W/kg (limb)
1-year warranty
Smart watch
A2999
iOS 18 or later
Notifications
Navigation
Activity / Sport
Tracking Data
Payment Technology
Apple Pay
Audio Input
Microphone with voice isolation
Audio Output
Speaker
Operating System
WatchOS 11
Wearing Style
Watch style
Feedback Type
Audio alert, vibration alert, visual interface
Clock Display
Set Goals
Sensors
Ambient light sensor, digital compass, depth gauge, electrical heart sensor, water temperature sensor, optical heart sensor (3d gen), always-on altimeter, temperature sensor, high-g accelerometer, gyroscope with high dynamic range
Storage
64 GB
Display
Retina LTPO3 OLED - colour
Resolution
416 x 496 pixels
Protection
Ion-X glass
Pixel Density
326 ppi
Always On Display (AOD)
Wireless Interface
IEEE 802.11n, Ultra-Wideband (UWB), Bluetooth 5.3
Input Device
Touch sensitive screen, side button, double tap gesture
CPU
Manufacturer
Apple
S10 SiP
W3 Apple wireless chip, second-generation Ultra Wideband chip, 4-core Neural Engine
Lithium Ion
Rechargeable Battery
Wireless Charging
Run Time (Up To)
18 hours
Run Time Details
Typical usage - up to 18 hour(s) , Low power mode - up to 36 hour(s)
Smart Watch Case
Case Shape
Rectangular
Case Size
46 mm
Crown Type
Digital with haptic feedback
Case Back
Metal and sapphire crystal back
Case Details
Silver aluminium
Band
Name
Sport band
Changeable
Size
S/M
140-190 mm
Clasp Type
Pin-and-tuck
Material
Fluoroelastomer
Denim
Details
Case only: 36.4 g
Internet of Things (IoT)
Siri
Voice Controlled
Direct
Preloaded Software
GymKit
Vibrating Alert
Body Material
Protection
Water-resistant, dust-resistant
IP6X, BFR-free, PVC-free, Mercury-free, Arsenic-free
Magnetic fast charger to USB-C cable (1 m)
Warranty
1-year warranty
Sustainability Information
Carbon Footprint
Max Depth of Water Resistance
50 m
35 °C
5 - 90% (non-condensing)
Max Altitude Operating
3000 m
HVT7 Apple Watch Charge cable USB-A In Stock £28.44
Brand: Apple
