Apple Watch Nike+, 42mm Silver Aluminium Case with Platinum / White Nike Sport Band
Quicklinx: D1Y9WS00 Mfr#: MQ192B/A
Select:
  • 42mm
To wear it is to love it. Receive and respond to notifications in an instant. Track your daily activity. Control your music using only your voice. Pay for groceries just like that. With this smartwatch, important information and essential features are always just a raise of the wrist away. Not to mention music, maps, and phone calls, smart watch lets you do the things you do every day, more easily and conveniently. As well as lots of things that simply weren't possible before. What you put on says a lot about you. And everyone is different. So the smartwatch was designed to reflect a wide range of tastes and styles. And you can make it even more personal, to suit the occasion or your mood, by switching bands and changing watch faces. Anytime you want.
  • The watch reimagined
    It delivers important information when and where you need it. Helps you easily perform everyday tasks in seconds. Instantly connects you to the people and things you care about most. All while keeping precise time.
  • You'll know it when you feel it
    Because this smartwatch sits on your wrist, it can give you a gentle tap the instant you receive an alert.
  • Stay in touch like never before
    You won't just send and receive messages, calls, and mail more easily and efficiently. You'll express yourself in unique, fun, and more personal ways. Communicating with the smartphone is discreet, sophisticated, and nuanced - a different way to connect with others.
  • Messages, calls, and mail designed for your wrist
    The ways you communicate on your smartphone are even more immediate on the smartwatch. To read a message or email, just raise your wrist. You can take a quick phone call using the built-in speaker and microphone.
  • Easy ways to respond
    You don't always have time to craft a lengthy response to a message or email. With the smartwatch, you can make a quick but meaningful reply.
  • Say it with feeling
    You don't even have to use words. The Digital Touch feature gives you fun, spontaneous ways to connect with other smartwatch wearers, wrist to wrist.
  • Sensitive enough to tell a tap from a press
    In addition to recognising touch, the smartwatch senses force, adding a different dimension to the user interface. With Force Touch, pressing firmly on the display brings up additional controls in apps.
  • Technology with a more human touch
    This linear actuator inside the smartwatch taps you on the wrist when you receive a notification, press down on the display, or use Digital Touch. The Taptic Engine gives different kinds of notifications and actions their own distinct character. So even with the accompanying audio cues turned off, you can feel the difference between an alarm and an incoming phone call without even looking.
Apple Watch Nike+ Series 2 - silver aluminium - smart watch with Nike sport band - pure platinum/white
Smart watch
Tracking Data
Distance, time, calories burned, activity, heart rate, steps taken
Wi-Fi, Bluetooth
Display
OLED 312 x 390 pixels - Ion-X glass
Apple S2
Operating System
WatchOS 3
Case
42 mm - aluminium
Band
Pure platinum/white - Nike sport band - fluoroelastomer - size: S/M/L
Input
Force Touch
Fits Wrist with Circumference
140-210 mm
Notifications
Calendar, SMS, Email
Call handling, Retina Display technology
Supported Host Device OS
iOS
Lithium Ion
Battery Run Time
Up to 18 hours
36.4 mm x 11.4 mm x 42.5 mm
34.2 g
SAR
0.058 W/kg (head), 0.054 W/kg (limb)
Smart watch
iOS 10 or later
Notifications
Tracking Data
Audio Input
Microphone
Audio Output
Speaker
Operating System
WatchOS 3
Wearing Style
Watch style
Clock Display
Set Goals
Sensors
Accelerometer, ambient light sensor, gyro sensor, heart rate
Display
OLED - colour
Resolution
312 x 390 pixels
Protection
Ion-X glass
Wireless Interface
IEEE 802.11b/g/n, Bluetooth 4.0
Input Device
Touch sensitive screen (Force Touch)
CPU
Manufacturer
Apple
S2
Lithium Ion
Run Time (Up To)
18 hours
Smart Watch Case
Case Size
42 mm
Crown Type
Digital
Case Back
Ceramic back
Case Details
Silver aluminium
Band
Name
Nike sport band
Size
S/M/L
140-210 mm
Clasp Type
Pin-and-tuck
Material
Fluoroelastomer
Pure platinum/white
36.4 mm
11.4 mm
42.5 mm
34.2 g
Preloaded Software
Siri, Nike+ Running
Vibrating Alert
Body Material
Aluminium
Protection
Waterproof
SAR Value
Power adapter, magnetic charging cable
Max Depth of Water Resistance
50 m
