Apple Watch Charge cable USB-A
Quicklinx: FZ2TWS00 Mfr#: MX2E2ZM/A
Device Type: Apple Watch
Type: Cable
Product Range: Apple
Product Model: Magnetic
£28.44 ex VAT
£34.12 inc VAT
It's a completely sealed system free of exposed contacts. And it's very forgiving, requiring no precise alignment. You simply hold the connector near the back of the watch, where magnets cause it to snap into place automatically.
  • Effortless charging
    The smart watch charging cable is designed with a magnetic charging connection, making it incredibly easy to attach and charge your device without the hassle of aligning ports.
  • Universal compatibility
    Equipped with a 4-pin USB Type-A connector, this cable ensures compatibility with a wide range of devices, allowing for versatile use across different platforms.
Apple Magnetic - smart watch charging cable - 1 m
Cable
Smart watch charging cable
Length
1 m
Connector
USB - male
Magnetic charging connection
Watch
Cable Type
Length
1 m
Connector
4 pin USB Type A - male
Apple Watch
Type: Cable
Brand: Apple
