Compact and convenient, the Apple USB SuperDrive connects to your MacBook Pro with Retina display, MacBook Air, or Mac mini with a single USB cable and fits easily into a travel bag. It lets you install software and play and burn both CDs and DVDs, including double-layer DVDs.
Everything you need in an optical drive
Whether you're at the office or on the road, you can play and burn both CDs and DVDs with the Apple USB SuperDrive. It's perfect when you want to watch a DVD movie, install software, create backup discs, and more. -
Take it anywhere
Only slightly bigger than a CD case, the Apple USB SuperDrive slips easily into your travel bag when you hit the road and takes up little space on your desk or tray table when you're working. -
The essence of simplicity
You'll never have to worry about lost cables with the Apple USB SuperDrive. It connects to your MacBook Pro with Retina display, MacBook Air, or Mac mini with a single USB cable that's built into the SuperDrive. There's no separate power adapter, and it works whether your Mac is plugged in or running on battery power.
- Apple USB SuperDrive - DVD±RW (±R DL) drive - USB 2.0 - external
- DVD±RW (±R DL) drive - external
- Interface
- USB 2.0
- 13.9 cm x 13.9 cm x 1.7 cm
- 335 g
- Optical Storage
- DVD±RW (±R DL)
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW)
- Media Load Type
- Slot-load
- Designed For
- iMac Pro (Late 2017); MacBook Pro with Retina display
- Interface
- USB 2.0
- 13.9 cm
- 13.9 cm
- 1.7 cm
- 335 g
Optical Storage
- DVD±RW (±R DL)
- Read Speed
- Write Speed
- Supported Media Formats
- CD-ROM
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
- Media Load Type
- Slot-load
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable - integrated
- Designed For
- Apple iMac Pro (Late 2017) , Apple MacBook Pro with Retina display
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.56 |
