Apple USB ethernet adaptor
Quicklinx: 7C65WS00 Mfr#: MC704ZM/A
The Apple USB Ethernet Adapter is a simple, one-piece external adapter that plugs into the USB 2.0 port of your MacBook Air to provide 10/100BASE-T performance. Simply plug your Ethernet cable into the RJ-45 connector - no external power is required. It's small, light, easy to install, and even easier to use.
Apple USB Ethernet Adapter - network adapter - USB 2.0 - 10/100 Ethernet
Network adapter
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
USB 2.0
Apple MacOS X 10.4.8 or later
Network adapter
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
Data Transfer Rate
100 Mbps
USB powered
USB 2.0
1 x 100Base-TX - RJ-45
1 x USB 2.0 - 4 pin USB Type A
1 x USB cable (integrated) - 11.7 cm
7C65 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
7C65 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.84
