This 1-metre charge cable is made with a woven design — with USB-C connectors on both ends — and is ideal for charging, syncing and transferring data between USB-C devices. It supports charging of up to 60 watts and transfers data at USB 2 rates. Pair the USB-C Charge Cable with a compatible USB-C power adapter to conveniently charge your devices from a power point and take advantage of fast-charging capabilities. USB-C power adapters sold separately.
                Durable designFeaturing a woven design, this USB-C cable is built for durability and long-lasting use. Its robust construction ensures it can withstand daily wear and tear, making it a reliable choice for charging and syncing your devices.
                Efficient charging and syncingEquipped with the capability to sync and charge, this cable offers efficient performance. Whether you're transferring data or charging your device, expect swift and reliable connectivity.
- Apple - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
- USB-C cable
- Sync and charge, woven design
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 1-year warranty
- USB-C cable
- Length
- 1 m
- Connector
- 1-year warranty
