Apple USB-C Woven Charge Cable (1m)
Quicklinx: H16QWS00 Mfr#: MQKJ3ZM/A
Type: Cable
48 In Stock
£21.19 ex VAT
£25.42 inc VAT
This 1-metre charge cable is made with a woven design — with USB-C connectors on both ends — and is ideal for charging, syncing and transferring data between USB-C devices. It supports charging of up to 60 watts and transfers data at USB 2 rates. Pair the USB-C Charge Cable with a compatible USB-C power adapter to conveniently charge your devices from a power point and take advantage of fast-charging capabilities. USB-C power adapters sold separately.
  • Durable design
    Featuring a woven design, this USB-C cable is built for durability and long-lasting use. Its robust construction ensures it can withstand daily wear and tear, making it a reliable choice for charging and syncing your devices.
  • Efficient charging and syncing
    Equipped with the capability to sync and charge, this cable offers efficient performance. Whether you're transferring data or charging your device, expect swift and reliable connectivity.
Apple - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1 m
USB-C cable
Sync and charge, woven design
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
1-year warranty
USB-C cable
Length
1 m
Connector
24 pin USB-C - male
24 pin USB-C - male
1-year warranty
Type: Cable
Brand: Apple
