Apple USB-C VGA Multiport Adapter
Quicklinx: B8SDWS00 Mfr#: MJ1L2ZM/A
10 In Stock
£60.24 ex VAT
£72.28 inc VAT
The USB-C VGA Multiport Adapter lets you connect your MacBook with USB-C port to a VGA display, while also connecting a standard USB device and a USB-C charging cable. The USB-C VGA Multiport Adapter allows you to mirror your MacBook display to your VGA-enabled TV or display in up to 1080p HD. It also outputs video content like films and captured video. Simply connect the adapter to the USB-C port on your MacBook and then to your TV or projector via a VGA cable (sold separately). Use the standard USB port to connect devices such as your flash drive or camera, or a USB cable for syncing and charging your iPhone, iPad, or iPod. You can also connect a charging cable to the USB-C port to charge your MacBook.
Apple USB-C VGA Multiport Adapter - VGA adapter
VGA adapter
Sync and charge
Connectors
24 pin USB-C - male
Connectors (Second End)
24 pin USB-C - female , HD-15 (VGA) - female , USB Type A - female
VGA adapter
Sync and charge
Connectors
24 pin USB-C - male
24 pin USB-C - female , 15 pin HD D-Sub (HD-15) - female , 9 pin USB Type A - female
Brand: Apple
