Apple USB-C to USB Adapter
Quicklinx: BGDCWS00 Mfr#: MJ1M2ZM/A
More than 50 in stock
£16.83 ex VAT
£20.19 inc VAT
Because it's made from a custom high-performance fluoroelastomer, the Sport Band is durable and strong, yet surprisingly soft. The smooth, dense material drapes elegantly across your wrist and feels comfortable next to your skin. An innovative pin-and-tuck closure ensures a clean fit.
Apple USB-C to USB Adapter - USB-C adapter - USB Type A to USB-C
USB-C adapter
Sync and charge
Connector
9 pin USB Type A - female
Connector (Second End)
24 pin USB-C - male
10.9-inch iPad Air (4th generation); 11-inch iPad Pro (1st generation, 2nd generation); 12.9-inch iPad Pro; iMac (Early 2019, Mid 2017); iMac Pro (Late 2017); Mac mini (Early 2020, Late 2018); Mac Pro (Late 2019); MacBook; MacBook Air (Late 2018, Mid 2019), with Retina display; MacBook Pro
USB-C adapter
Sync and charge
Connector
24 pin USB-C - male
Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation) , Apple iMac (Early 2019, Mid 2017) , Apple iMac Pro (Late 2017) , Apple Mac mini (Early 2020, Late 2018) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Late 2018, Mid 2019), with Retina display (Early 2020, Late 2018, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Mid 2017, Mid 2018, Mid 2019)
Brand: Apple
Stock Status: In stock
