Apple USB-C to USB Adapter
Quicklinx: BGDCWS00 Mfr#: MJ1M2ZM/A
Length: [N/A]
38 In Stock
£17.39 ex VAT
£20.86 inc VAT
Because it's made from a custom high-performance fluoroelastomer, the Sport Band is durable and strong, yet surprisingly soft. The smooth, dense material drapes elegantly across your wrist and feels comfortable next to your skin. An innovative pin-and-tuck closure ensures a clean fit.
  • Effortless connectivity
    The Apple USB-C to USB Adapter offers seamless connectivity between your Mac and USB devices. With a simple Plug-and-Play design, this adapter ensures you can connect USB cables, flash drives, and other peripherals to your Mac without any hassle.
  • Durable design
    Crafted with durability in mind, the adapter features a robust cable that's designed for both syncing and charging your devices. This ensures a reliable connection and longevity, making it an essential accessory for your Mac.
Apple USB-C to USB Adapter - USB-C adapter - USB Type A to 24 pin USB-C
USB-C adapter
Sync and charge
Connector
9 pin USB Type A - female
Connector (Second End)
24 pin USB-C - male
USB-C adapter
Sync and charge
Connector
24 pin USB-C - male
Length: [N/A]
Brand: Apple
