Experience the convenience of the Apple Lightning cable, designed to meet the needs of your lifestyle. This cable features male connectors on both ends, including a 24-pin USB-C and an Apple Lightning connector, making it versatile for a variety of devices. Whether you're at home, in the office, or on-the-go, this cable ensures your devices stay connected and charged. Its recommended use for cellular phones and tablets, along with the ability to sync and charge, makes it an essential accessory for any Apple device owner. Enjoy the reliability and efficiency that comes with using an Apple-designed cable.
Efficient syncing and charging
Designed to provide a seamless connection between your devices, this Apple Lightning cable ensures efficient syncing and charging. Whether you're looking to transfer data or keep your device powered up, this cable has you covered. -
Versatile compatibility
With a 24-pin USB-C connector on one end and an Apple Lightning connector on the other, this cable is perfect for a wide range of Apple devices. From cellular phones to tablets, it offers the flexibility you need to connect your devices effortlessly.
- Apple Lightning cable - 2 m
- Cable
- Lightning cable
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Lightning - male
- Sync and charge
- 1-year warranty
- Cable Type
- Lightning cable
- Length
- 2 m
- Recommended Use
- Mobile phone, tablet
- Sync and charge
- Connector
- Apple Lightning - male
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HTMV 051225 Condition: Damaged stock - Item is new but has packaging damage |
£13.27 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
