Brand
Apple USB-C to Lightning Cable 2m
Quicklinx: GR91WS00 Mfr#: MQGH2ZM/A
Product Range: Apple
More than 50 In Stock
£32.09 ex VAT
£38.50 inc VAT
Connect your iPhone, iPad, or iPod with Lightning connector to your USB-C - or Thunderbolt 3 (USB-C) - enabled Mac for syncing and charging, or to your USB-C - enabled iPad for charging.
You can also use this cable with your Apple 18W, 20W, 29W, 30W, 61W, 87W or 96W USB-C Power Adapter to charge your iOS device and even take advantage of the fast-charging feature on selected iPhone and iPad models.
Apple Lightning cable - Lightning / USB - 2 m
Cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
Lightning - male
1-year warranty
Apple Wireless Charging Case; 10.2-inch iPad; 10.5-inch iPad Air; 10.9-inch iPad; 9.7-inch iPad; AirPods; AirPods Max; AirPods Pro; iPad mini; iPad mini 4; 5; iPhone 11, 12, 13, 14, 5, 5c, 5s, 6, 6s, 7, 8, SE, X, XR, XS, XS Max
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Length
2 m
Recommended Use
Mobile phone, tablet, digital player
Connector
24 pin USB-C - male
Apple Lightning - male
Limited warranty - parts and labour - 1 year
Apple Wireless Charging Case , Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.9-inch iPad (10th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple AirPods (1st generation, 2nd generation, 3rd generation) , Apple AirPods Max , Apple AirPods Pro (1st generation, 2nd generation) , Apple iPad mini (6th generation) , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 14, 14 Plus, 14 Pro, 14 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), SE (3rd generation), X, XR, XS, XS Max
Brand: Apple
