Connect your device with Lightning connector to your USB-C– or Thunderbolt 3 (USB-C)–enabled device for syncing and charging, or to your USB-C–enabled iPad for charging.
You can also use this cable with your Apple 18W, 20W, 29W, 30W, 61W, 87W or 96W USB-C Power Adapter to charge your iOS device and even take advantage of the fast-charging feature on selected iPhone and iPad models.
- Apple USB-C to Lightning Cable - Lightning cable - 1 m
- Cable
- Lightning cable
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Lightning - male
- Cable Type
- Lightning cable
- Length
- 1 m
- Recommended Use
- Mobile phone, headphones, tablet, digital player
- Connector
- Apple Lightning - male
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HP7G 051041 Condition: Customer return - item has been opened but is in excellent condition |
£10.36 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
