Apple USB-C to Lightning Cable - 1 m
Quicklinx: HP7GWS00 Mfr#: MUQ93ZM/A
Length: 1m
More than 50 In Stock
£16.41 ex VAT
£19.69 inc VAT
Express delivery Order within the next 16 hours for delivery tomorrow
Connect your device with Lightning connector to your USB-C– or Thunderbolt 3 (USB-C)–enabled device for syncing and charging, or to your USB-C–enabled iPad for charging.
You can also use this cable with your Apple 18W, 20W, 29W, 30W, 61W, 87W or 96W USB-C Power Adapter to charge your iOS device and even take advantage of the fast-charging feature on selected iPhone and iPad models.
Apple USB-C to Lightning Cable - Lightning cable - 1 m
Cable
Lightning cable
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
Lightning - male
Cable Type
Lightning cable
Length
1 m
Recommended Use
Mobile phone, headphones, tablet, digital player
Connector
24 pin USB-C - male
Apple Lightning - male
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HP7G 051041
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £10.36
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Length: 1m
Brand: Apple
Stock Status: Used Stock
