The USB-C to Lightning Adapter lets you connect your Lightning accessories to a USB-C-enabled iPhone or iPad to conveniently provide three key functions — charging, data and audio — with a single adapter. This adapter has a braided cable for added durability.
Plug the USB-C end of the adapter into the USB-C connector on your iPhone or iPad, then connect your Lightning accessory.
This adapter supports connection to most cars, including those that work with CarPlay. You can also directly connect a USB cable from your car into the USB-C connector on your iPhone. Learn more about compatibility options in this article.
Durable design
Featuring a braided cable, this Apple Lightning adapter is designed for enhanced durability and resistance against wear and tear, ensuring a longer lifespan for your essential accessory. -
Seamless connectivity
With a male 24-pin USB-C connector on one end and a female Apple Lightning connector on the other, this adapter ensures a seamless connection between your devices, enabling efficient charging and data transfer.
- Apple Lightning adapter
- Cable
- Lightning adapter
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Lightning - female
- Braided
- 1-year warranty
- Cable Type
- Lightning adapter
- Braided
- Connector
- Apple Lightning - female
- Limited warranty - 1 year
