The USB-C Digital AV Multiport Adapter lets you connect your USB-C-enabled Mac or iPad Pro to an HDMI display, while also connecting a standard USB device and a USB-C charging cable. This adapter allows you to mirror your Mac display to your HDMI-enabled TV or display.
High-resolution support
Experience crystal-clear visuals with the Digital AV Multiport Adapter, supporting up to 3840 x 2160 max output resolution at a 60 Hz refresh rate. This feature ensures your presentations and media are displayed in stunning detail and fluid motion, making it suitable for professional and home environments. -
Versatile connectivity
The adapter offers a wide range of connectivity options with its HDMI, USB, and Thunderbolt 3 compliant standards. Whether you're connecting to a display, charging your device, or transferring data, this adapter has you covered. The inclusion of both male and female connectors, including 24-pin USB-C and 19-pin HDMI Type-A, ensures compatibility with a variety of devices and setups. -
4K support
Elevate your viewing experience with 4K support, allowing you to enjoy high-definition content at its finest. Whether it's for gaming, streaming, or professional applications, the Digital AV Multiport Adapter delivers exceptional quality visuals that bring your screen to life.
- Apple Digital AV Multiport Adapter - adapter - HDMI / USB
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Connectors
- 24 pin USB-C - male
- Connectors (Second End)
- HDMI - female , USB - female , USB-C (power only) - female
- Thunderbolt 3
- 4K support
- Cable Type
- Adapter 4K support
- Interface Supported
- HDMI / USB
- Thunderbolt 3
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- Connectors
- 19 pin HDMI Type A - female , 4 pin USB Type A - female , 24 pin USB-C (power only) - female
