Apple USB-C Charge Cable (2m)
Quicklinx: CGPBWS00 Mfr#: MLL82ZM/A
Length: 2m
More than 50 In Stock
£15.61 ex VAT
£18.73 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
This 2-meter charge cable — with USB-C connectors on both ends — is ideal for charging USB-C devices and supports USB 2 for syncing and data transfer between USB-C devices. To conveniently charge your MacBook or MacBook Pro from a wall outlet, pair the USB-C Charge Cable with a compatible USB-C power adapter.
Apple USB-C Charge Cable - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
USB-C cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB-C cable
Length
2 m
Connector
24 pin USB-C - male
24 pin USB-C - male
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CGPB 050670
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £12.36
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Length: 2m
Brand: Apple
Stock Status: Used Stock
