Apple USB-C Charge Cable (2m)
Quicklinx: CGPBWS00 Mfr#: MLL82ZM/A
Length: 2m
More than 50 in stock
£16.23 ex VAT
£19.47 inc VAT
This 2-meter charge cable — with USB-C connectors on both ends — is ideal for charging USB-C devices, and also supports USB 2 for syncing and data transfer between USB-C devices. To conveniently charge your MacBook or MacBook Pro from a wall outlet, pair the USB-C Charge Cable with a compatible USB-C power adapter.
Apple USB-C Charge Cable - USB-C cable - USB-C to USB-C - 2 m
USB-C cable
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
10.9-inch iPad Air (4th generation); 11-inch iPad Pro; 12.9-inch iPad Pro; iMac (Early 2019, Early 2021, Mid 2017); iMac Pro (Late 2017); Mac mini (Early 2020, Late 2018, Late 2020); Mac Pro (Late 2019); MacBook (Early 2015, Early 2016, Mid 2017); MacBook Air; MacBook Pro
USB-C cable
Length
2 m
Connector
24 pin USB-C - male
24 pin USB-C - male
Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation) , Apple iMac (Early 2019, Early 2021, Mid 2017) , Apple iMac Pro (Late 2017) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Mid 2017, Mid 2018, Mid 2019)
Length: 2m
Brand: Apple
Stock Status: In stock
