This 2-meter charge cable — with USB-C connectors on both ends — is ideal for charging USB-C devices and supports USB 2 for syncing and data transfer between USB-C devices. To conveniently charge your MacBook or MacBook Pro from a wall outlet, pair the USB-C Charge Cable with a compatible USB-C power adapter.
 - Apple USB-C Charge Cable - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
 - USB-C cable
- Length
 - 2 m
- Connector
 - 24 pin USB-C - male
- Connector (Second End)
 - USB-C cable
- Length
 - 2 m
- Connector
