This 2-meter charge cable — with USB-C connectors on both ends — is ideal for charging USB-C devices and supports USB 2 for syncing and data transfer between USB-C devices. To conveniently charge your MacBook or MacBook Pro from a wall outlet, pair the USB-C Charge Cable with a compatible USB-C power adapter.
- Apple USB-C Charge Cable - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB-C cable
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB-C cable
- Length
- 2 m
- Connector
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CGPB 048630 Condition: Customer return - item has been opened but is in excellent condition |
£10.11 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
