This 2-meter charge cable — with USB-C connectors on both ends — is ideal for charging USB-C devices and supports USB 2 for syncing and data transfer between USB-C devices. To conveniently charge your MacBook or MacBook Pro from a wall outlet, pair the USB-C Charge Cable with a compatible USB-C power adapter.
- Apple USB-C Charge Cable - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB-C cable
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB-C cable
- Length
- 2 m
- Connector
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CGPB 051360 Condition: Customer return - item has been used but is in excellent condition |
£12.36 |
Ref:
CGPB 051383 Condition: Customer return - item has been opened but is in excellent condition |
£10.16 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
