The Apple Thunderbolt to Gigabit Ethernet Adapter lets you easily connect to a high-performance Gigabit Ethernet network. Small and compact, it connects to the Thunderbolt port on your Mac computer and provides an RJ-45 port that supports 10/100/1000BASE-T networks.
Compatibility
- Mac: OS X v10.7.4 or later
- Thunderbolt-equipped Mac computer
What's in the Box?
- Apple Thunderbolt to Gigabit Ethernet Adapter with built-in Thunderbolt cable
- Apple Thunderbolt to Gigabit Ethernet Adapter - network adapter - Thunderbolt - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- Thunderbolt
- Ports
- Gigabit Ethernet
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- System Requirements
- Apple MacOS X 10.7.4 or later
- Designed For
- iMac with Retina 4K display (Late 2015), with Retina 5K display (Late 2014, Late 2015, Mid 2015); Mac mini (Late 2014); Mac Pro (Late 2013); MacBook Air (Early 2015, Mid 2017); MacBook Pro (Early 2013, Early 2015, Late 2012, Late 2013, Mid 2012, Mid 2014, Mid 2015)
- Network adapter
- Form Factor
- External
- Thunderbolt
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 1 x 1000Base-T - RJ-45 - female
- OS Required
- Designed For
- Apple iMac with Retina 4K display (Late 2015), with Retina 5K display (Late 2014, Late 2015, Mid 2015) , Apple Mac mini (Late 2014) , Apple Mac Pro (Late 2013) , Apple MacBook Air (Early 2015, Mid 2017) , Apple MacBook Pro (Early 2013, Early 2015, Late 2012, Late 2013, Mid 2012, Mid 2014, Mid 2015)
