Apple Thunderbolt to Gigabit Ethernet Adapter
Quicklinx: 84ZHWS00 Mfr#: MD463ZM/A
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet
Form Factor: External
Compatibility: Mac
Type: Network adapter
£17.49 ex VAT
£20.98 inc VAT
Express delivery Order within the next 30 minutes for delivery on Monday
The Apple Thunderbolt to Gigabit Ethernet Adapter lets you easily connect to a high-performance Gigabit Ethernet network. Small and compact, it connects to the Thunderbolt port on your Mac computer and provides an RJ-45 port that supports 10/100/1000BASE-T networks.
Compatibility
  • Mac: OS X v10.7.4 or later
  • Thunderbolt-equipped Mac computer
What's in the Box?
  • Apple Thunderbolt to Gigabit Ethernet Adapter with built-in Thunderbolt cable
Apple Thunderbolt to Gigabit Ethernet Adapter - network adapter - Thunderbolt - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
Thunderbolt
Ports
Gigabit Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Apple MacOS X 10.7.4 or later
iMac with Retina 4K display (Late 2015), with Retina 5K display (Late 2014, Late 2015, Mid 2015); Mac mini (Late 2014); Mac Pro (Late 2013); MacBook Air (Early 2015, Mid 2017); MacBook Pro (Early 2013, Early 2015, Late 2012, Late 2013, Mid 2012, Mid 2014, Mid 2015)
Network adapter
External
Thunderbolt
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
1 x 1000Base-T - RJ-45 - female
Apple iMac with Retina 4K display (Late 2015), with Retina 5K display (Late 2014, Late 2015, Mid 2015) , Apple Mac mini (Late 2014) , Apple Mac Pro (Late 2013) , Apple MacBook Air (Early 2015, Mid 2017) , Apple MacBook Pro (Early 2013, Early 2015, Late 2012, Late 2013, Mid 2012, Mid 2014, Mid 2015)
Protocol: Gigabit Ethernet
Protocol: Ethernet
Compatibility: Mac
Brand: Apple
Stock Status: While stocks last
Stock Status: Clearance
