Apple Thunderbolt Display 27" 2560x1440 5ms IPS LED Monitor
Quicklinx: 8BN2WS00 Mfr#: MC914B/B
With built-in Thunderbolt technology - the fastest, most flexible I/O ever - the Apple Thunderbolt Display can do things other displays simply can't. Of course, it delivers a brilliant viewing experience. But connect it to any Thunderbolt-enabled Mac and it becomes a Plug-and-Play hub for everything you do. Features include a high-resolution 2560-by-1440 LED-backlit display, a FaceTime HD camera, high-quality audio, three USB 2.0 ports, a FireWire 800 port, a Gigabit Ethernet port, and a Thunderbolt port for daisy-chaining additional high-performance devices.
  • Thunderbolt technology built in
    Thunderbolt I/O technology lets you move data between your devices and your computer with unprecedented speed. With two channels of 10-Gbps throughput in both directions, it's up to 20 times faster than USB 2.0 and up to 12 times faster than FireWire 800. And it allows you to connect as many as six devices through a single, compact port.
  • The ultimate docking station
    With just one cable, connect any Thunderbolt-enabled Mac and get 27 inches of high-resolution screen space, high-quality audio, a FaceTime HD camera, FireWire 800 and Gigabit Ethernet ports - and a Thunderbolt port you can use to daisy-chain additional high-performance peripherals such as hard drives and video capture devices.
  • Plug in and power up
    The Thunderbolt Display includes a MagSafe connector that powers and charges your MacBook Pro or MacBook Air. The connector sits on your desk, ready and waiting. No need to unwind the cord to the power adapter that came with your notebook. Leave it exactly where it is, in your bag.
  • A bigger display for your biggest ideas
    Connect your Thunderbolt-enabled Mac to the Thunderbolt Display for a panoramic viewing experience unlike any other. This huge 27-inch glossy widescreen display features a cinematic 16:9 aspect ratio and an astonishing 2560-by-1440 resolution. That gives you more room to work with apps on your MacBook Air. More pixels for your MacBook Pro. And a worthy desktop companion to your iMac or Mac mini.
  • LED backlighting
    Full brightness with no waiting. That's the big advantage of LED backlight technology. Unlike most displays that take time to warm up before they reach maximum brightness, an LED-backlit display is instantly on and uniformly bright. LED backlighting also gives you greater control over screen brightness. So you can tune the Thunderbolt Display to suit the ambient light in even the dimmest room.
  • Built-in FaceTime HD camera and microphone
    With the built-in FaceTime HD camera and microphone, you can connect your Mac desktop or notebook - open or closed - and make HD video calls or take a few snapshots using Photo Booth.
Apple Thunderbolt Display - LED monitor - 27"
LED-backlit LCD monitor - 27"
Microphone, camera, USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
375 cd/m²
Contrast Ratio
1000:1
Response Time
12 ms
Colour Support
16.7 million colours
Input Connectors
Thunderbolt
Built-in Ethernet
Speakers
Integrated
Voltage
AC 120/230 V (50 - 60 Hz)
65 cm x 20.7 cm x 49.1 cm
10.8 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Display Type
Diagonal Size
27"
Built-in Devices
Camera, USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
375 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
12 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Ambient light sensor, MagSafe connector
10.8 kg
Audio
Speakers with subwoofer - stereo with subwoofer - integrated
Input
Microphone
Thunderbolt , 3 x USB 2.0 , FireWire 800 , Network (RJ-45)
1 x Thunderbolt cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
250 Watt
Power Consumption Stand by / Sleep
2 Watt
Apple MacOS X 10.6.8 or later
Dimensions & Weight Details
Width: 65 cm - height: 49.1 cm - weight: 10.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
10 °C
35 °C
20 - 80% (non-condensing)
8BN2 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
