Apple Thunderbolt 3 USB-C Cable 0.8M
Quicklinx: DSR3WS00 Mfr#: MQ4H2ZM/A
Length: 80cm
More than 50 in stock
£37.50 ex VAT
£45.00 inc VAT
This 0.8-meter cable supports Thunderbolt 3 data transfer up to 40 Gbps, USB 3.1 Gen 2 data transfer up to 10 Gbps, DisplayPort video output (HBR3), and charging up to 100 W. Use this cable to connect a Mac with Thunderbolt 3 (USB-C) to Thunderbolt 3 devices such as docks, hard drives, and displays. You can daisy-chain up to six Thunderbolt 3 devices.
Apple Thunderbolt cable - USB-C to USB-C - 80 cm
Thunderbolt cable
Up to 100 Watts of power delivery
Length
80 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3
10.9-inch iPad Air (4th generation); 11-inch iPad Pro (1st generation, 2nd generation); 12.9-inch iPad Pro; iMac (Early 2019, Mid 2017); iMac Pro (Late 2017); Mac mini (Early 2020, Late 2018); Mac Pro (Late 2019); MacBook; MacBook Air (Late 2018, Mid 2019), with Retina display; MacBook Pro
Thunderbolt cable
Length
80 cm
Connector
24 pin USB-C - male
24 pin USB-C - male
Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation) , Apple iMac (Early 2019, Mid 2017) , Apple iMac Pro (Late 2017) , Apple Mac mini (Early 2020, Late 2018) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Late 2018, Mid 2019), with Retina display (Early 2020, Late 2018, Mid 2019) , Apple MacBook Pro (Late 2016, Late 2019, Mid 2017, Mid 2018, Mid 2019)
Length: 80cm
Brand: Apple
Stock Status: In stock
