Apple Studio Display - 27" 5120x2880 Tilt-Adjustable Stand
Quicklinx: GS06WS00 Mfr#: MK0U3B/A
Diagonal Size: 27in
Max Resolution: 5120 x 2880
Response Time: [N/A]
Speakers: Speakers with subwoofer
Interfaces: Thunderbolt 3
Hurry, only 3 left in stock!
£1,214.47 ex VAT
£1,457.36 inc VAT
The Apple Studio Display combines state-of-the-art digital imaging technology with advanced software-based features unique to Apple. The result is a high-performance flat panel display that's ideal for anyone who spends a lot of time manipulating text, graphics, and other media on-screen. Whether you're a multimedia content creator, a designer, a writer, an educator, or an accountant, the Apple Studio Display can make your job look a lot better to you-and vice versa. The TFT active-matrix LCD technology used by the Apple Studio Display enables it to offer outstanding brightness, contrast ratio, and sharpness-for optimal viewing. It also provides an impressively wide viewing angle, as well as eliminating screen flicker. And the Apple Studio Display offers all this performance in a product that's a fraction the size of a traditional computer monitor.
Probably the most distinguishing feature of this display, though, is the advantage it takes of Apple's outstanding hardware/software integration. In the case of the Apple Studio Display, this enables an unmatched combination of "smart features" and superior software controls-adding up to an extraordinarily flexible, responsive device with which to view your work. In fact, the Apple Studio Display can make that eight-plus hours per day you spend in front of your computer significantly more productive - and surprisingly more pleasant. If you deal primarily with graphics, you'll be glad to know that the Apple Studio Display requires no special graphics adapter to work seamlessly with your computer. If you deal more with multimedia, you'll appreciate its built-in connectors for composite and S-video as well as audio input. And if what you deal with most frequently is a combination, you'll find the display's ability to shift instantly between graphics and video modes invaluable. The Apple Studio Display-when you look at all its high-performance capabilities, you'll really like what you see.
  • See what you can do
    A big, beautiful window into new worlds, Studio Display draws you in from the moment you turn it on. It has a slim, all-screen design. And it's packed with a phenomenal set of features so everything you do springs to life with gorgeous color and spectacular detail.
  • Sensational camera and audio
    12MP Ultra Wide camera with Center Stage. Studio Display includes a highly advanced camera with a 12MP sensor and a 122-degree field of view. And thanks to Apple silicon, it features Center Stage, which comes to Mac for the first time. Center Stage keeps you centered in the frame as you move around, making video calls more engaging. When others join or leave the call, the view expands or zooms in. It also works beautifully with your go-to video conferencing apps.
  • Six speakers, cinematic sound
    Four force-canceling woofers produce bold, articulate bass and minimize distortion. And two high-performance tweeters deliver accurate mids and crisp highs. Altogether, this is the highest-fidelity speaker system ever created for Mac.
  • Hear, there, and everywhere
    Spatial Audio immerses you in sound. It's like having your own personal movie theater or concert hall. When you're playing music or video with Dolby Atmos, the A13 Bionic chip works with all six speakers to create a sophisticated, cinematic soundstage.
  • Take charge of your studio
    Three USB-C ports let you connect, power, and charge devices - from networking and external drives to your keyboard, mouse, or iPhone. The Thunderbolt port connects Studio Display to your Mac with a single cable. That same port can charge compatible Mac notebooks - and even fast-charge a 14-inch MacBook Pro.
  • Stands, and delivers
    Studio Display comes with a choice of two stands or a mount adapter, so you can find the right angle for your needs.
Apple Studio Display Standard glass - LCD monitor - 5K - 27" - with tilt-adjustable stand
LCD monitor - 27"
Energy Class
Class E
12 megapixel camera, 6 speakers, 3 microphone beam forming array, USB PD 96 Watt
Native Resolution
5K 5120 x 2880
Brightness
600 cd/m²
Colour Support
1 billion colours
Input Connectors
Thunderbolt 3
Audio Input
3-microphone array
Built-in Webcam
12 Megapixel (ultra wide)
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
62.3 cm x 16.8 cm x 47.8 cm
6.3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Display Type
LCD monitor
Energy Class
Class E
Diagonal Size
27"
Built-in Devices
USB Power Delivery
96 Watt
Native Resolution
5K 5120 x 2880
Pixel Per Inch
218
Brightness
600 cd/m²
Colour Support
1 billion colours
Retina display, P3 Wide Color Gamut, True Tone technology, standard glass, Dolby Atmos
6.3 kg
Built-in Webcam
Sensor Resolution
122° field of view, F 2.4 lens aperture, Center Stage
Audio Input
3-microphone array
Audio
Speakers with subwoofer - stereo with subwoofer
Thunderbolt 3 / USB-C (power up to 96W) , 3 x USB-C
Mechanical
Tilt
Tilt Angle
-5/+25
Spatial Audio, A13 Bionic chip
1 x Thunderbolt cable - 1 m
Input Voltage
21.2 kWh/1000h
Included Software
Siri
Apple macOS Monterey 12.3 or later, Apple iPadOS 15.4 or later
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
10 °C
35 °C
5 - 90% (non-condensing)
Diagonal Size: 27in
Brand: Apple
Price Range Ex VAT: £1000 - £1500
