Apple Studio Display - 27" 5120x2880 Tilt- and Height-Adjustable
Quicklinx: GRZZWS00 Mfr#: MK0Q3B/A
The Apple Studio Display combines state-of-the-art digital imaging technology with advanced software-based features unique to Apple. The result is a high-performance flat panel display that's ideal for anyone who spends a lot of time manipulating text, graphics, and other media on-screen. Whether you're a multimedia content creator, a designer, a writer, an educator, or an accountant, the Apple Studio Display can make your job look a lot better to you-and vice versa. The TFT active-matrix LCD technology used by the Apple Studio Display enables it to offer outstanding brightness, contrast ratio, and sharpness-for optimal viewing. It also provides an impressively wide viewing angle, as well as eliminating screen flicker. And the Apple Studio Display offers all this performance in a product that's a fraction the size of a traditional computer monitor.
Probably the most distinguishing feature of this display, though, is the advantage it takes of Apple's outstanding hardware/software integration. In the case of the Apple Studio Display, this enables an unmatched combination of "smart features" and superior software controls-adding up to an extraordinarily flexible, responsive device with which to view your work. In fact, the Apple Studio Display can make that eight-plus hours per day you spend in front of your computer significantly more productive - and surprisingly more pleasant. If you deal primarily with graphics, you'll be glad to know that the Apple Studio Display requires no special graphics adapter to work seamlessly with your computer. If you deal more with multimedia, you'll appreciate its built-in connectors for composite and S-video as well as audio input. And if what you deal with most frequently is a combination, you'll find the display's ability to shift instantly between graphics and video modes invaluable. The Apple Studio Display-when you look at all its high-performance capabilities, you'll really like what you see.
  • Legal
    ¹Screen size is measured diagonally.
Apple Studio Display Standard glass - LCD monitor - 5K - 27" - with tilt- and height-adjustable stand
LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1053323
Energy Class
Class E
12 megapixel camera, 6 speakers, 3 microphone beam forming array, USB PD 96 watt
Native Resolution
5K 5120 x 2880
Brightness
600 cd/m²
Colour Support
1 billion colours
Input Connectors
Thunderbolt 3
Audio Input
3-microphone array
Built-in Webcam
12 Megapixel (ultra wide)
Display Position Adjustments
Height, tilt
Voltage
AC 100-240 V (50/60 Hz)
62.3 cm x 20.7 cm x 47.9 cm
7.7 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Display Type
LCD monitor
Energy Class
Class E
Diagonal Size
27"
Built-in Devices
USB Power Delivery
96 watt
Native Resolution
5K 5120 x 2880
Pixel Per Inch
218
Brightness
600 cd/m²
Colour Support
1 billion colours
Retina display, P3 Wide Color Gamut, True Tone technology, standard glass, Dolby Atmos
7.7 kg
Built-in Webcam
Sensor Resolution
122° field of view, F 2.4 lens aperture, Center Stage
Audio Input
3-microphone array
Audio
Speakers with subwoofer - stereo with subwoofer
Thunderbolt 3 / USB-C (power up to 96W) , 3 x USB-C
Mechanical
Height, tilt
Tilt Angle
-5/+25
Height Adjustment
105 mm
Spatial Audio, A13 Bionic chip
1 x Thunderbolt cable - 1 m
Input Voltage
21.2 kWh/1000h
Included Software
Siri
Apple macOS Monterey 12.3 or later, Apple iPadOS 15.4 or later
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
10 °C
35 °C
5 - 90% (non-condensing)
