Apple Siri Remote
Apple Siri Remote
Quicklinx: H184WS00 Mfr#: MNC73Z/A
The Siri Remote (3rd generation) brings precise control to your Apple TV 4K.¹ Its touch-enabled clickpad lets you select titles, swipe through playlists, and use a circular gesture on the outer ring to find just the scene you’re looking for. With Siri, you can find what you want to watch using your voice. And the latest design includes a USB-C port to quickly recharge.
Apple Siri Remote 3rd Generation remote control
Remote control
3.5 cm x 0.925 cm x 13.6 cm
66 g
Infrared
Supported Devices
Apple TV 4K, mediabox, Apple TV HD
Input Device
Touchpad, microphone
Wireless Technology
Bluetooth 5.0
Audio Input
Microphone
Rechargeable
1-year warranty
Remote control
3.5 cm
0.925 cm
13.6 cm
66 g
Infrared
Wireless Technology
Bluetooth 5.0
Supported Devices
Input Device
Voice control
Audio Input
Microphone
Connector Type
USB-C (power only)
35 °C
5 - 95% (non-condensing)
Rechargeable
Limited warranty - 1 year
