Apple Siri Remote
Apple Siri Remote
Quicklinx: G968WS00 Mfr#: MJFM3ZM/A
The Siri Remote (2nd generation) brings precise control to your Apple TV 4K and Apple TV HD.¹ Its all-new touch-enabled clickpad lets you click titles, swipe through playlists and use a circular gesture on the outer ring to easily fast-forward or rewind. And with Siri, you can find what you want to watch using just your voice.
  • Effortless control
    The Apple Siri Remote (2nd Generation) offers voice control capabilities, allowing users to navigate and interact with their devices seamlessly without manual input. Its integration of both infrared and Bluetooth 5.0 technologies ensures a responsive and reliable connection, enhancing user experience.
  • Durable design
    Equipped with a rechargeable lithium-ion battery and designed to operate in a wide range of environmental conditions, from 5 - 95% humidity (non-condensing) and temperatures between 0°C and 35°C, the Apple Siri Remote is built to last and perform in various settings, ensuring reliability and longevity.
  • Convenient connectivity
    Featuring an Apple Lightning connection, the Siri Remote offers a straightforward and efficient charging solution. This design choice underscores the remote's ease of use and compatibility with other Apple products, providing a cohesive ecosystem experience.
Apple Siri Remote 2nd Generation remote control
Remote control
3.5 cm x 9.25 cm x 13.6 cm
63 g
Infrared
Supported Devices
Mediabox
Wireless Technology
Bluetooth 5.0
Audio Input
Microphone
Rechargeable - Lithium Ion
Remote control
3.5 cm
9.25 cm
13.6 cm
63 g
Infrared
Wireless Technology
Bluetooth 5.0
Supported Devices
Mediabox
Voice control
Audio Input
Microphone
Connector Type
Apple Lightning
Lightning to USB cable
35 °C
5 - 95% (non-condensing)
