Every aspect of Pro Stand was designed with pros in mind. Height, tilt, rotation - it's completely adjustable, allowing your Pro Display XDR to fit seamlessly into any work environment.
Height adjustment and tilt
With precision tilting and 120mm of total height adjustment, Pro Stand helps Pro Display XDR adapt to any viewing condition. When you adjust the height, the angle of the display stays true. Thanks to a highly sophisticated mechanism in the arm, the display feels weightless, moves effortlessly and stays exactly where you want it. -
Rotation
Pro Stand gives you the ability to easily transition between landscape and portrait whenever you want. Change the screen's orientation by simply unlocking the slider and turning the display anticlockwise. This flexibility allows the display to quickly adapt to a pro's changing content.
- Apple Pro Stand stand - for Monitor
- Product Type
- Stand - desktop
- 18 cm x 23.6 cm x 49.7 cm
- Tilt
- -5° to 20°
- Adjustments
- Height, tilt, rotation
- 4.3 kg
- Recommended Use
- Monitor
- Designed For
- Pro Display XDR
- 18 cm
- 23.6 cm
- 49.7 cm
- 4.3 kg
AV Furniture
- Stand
- Recommended Use
- Monitor
- Placing / Mounting
- Desktop
- Tilt
- -5° to 20°
- Adjustments
- Designed For
- Apple Pro Display XDR
Apple Pro Stand for Pro Display XDR
