The contrast your eyes see between brightness and darkness is very challenging to reproduce in a display, leading to the development of High Dynamic Range (HDR). With breakthrough backlighting technology, Pro Display XDR takes brightness, contrast, and color to the high level. Far beyond HDR, it's Extreme Dynamic Range (XDR).
 - Apple Pro Display XDR Standard glass - LED monitor - 32"
 - LED-backlit LCD monitor - 32"
- Energy Class
 - Class G
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - 6016 x 3384 at 60 Hz
- Brightness
 - 1600 cd/m²
- Contrast Ratio
 - 1000000:1
- Colour Support
 - 1.074 billion colours (10-bit)
- Input Connectors
 - Thunderbolt 3
- Screen Coating
 - Anti-glare
- Voltage
 - AC 120/230 V (50 - 60 Hz)
- Dimensions (WxDxH) - without stand
 - 71.8 cm x 2.7 cm x 41.2 cm
 - 7.48 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - ENERGY STAR Qualified
 - 1-year warranty
- Display Type
- Energy Class
 - Class G
- Energy Class (HDR)
 - Class G
- Diagonal Size
 - 32"
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Per Inch
 - 218
- Brightness
 - 1600 cd/m²
- Contrast Ratio
 - 1000000:1
- Colour Support
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
 - Anti-glare
- Backlight Technology
 - LED backlight
 - Aluminum enclosure, BFR/PVC-free, Mercury free, beryllium free, arsenic free, Retina display, fully laminated display, True Tone display, 10-bit Colour Depth, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), dual ambient light sensor
 - 71.8 cm x 2.7 cm x 41.2 cm - without stand
 - 7.48 kg
 - Thunderbolt 3 / USB-C (power up to 95W) , 3 x USB-C
- Included Accessories
 - Cleaning cloth
- Cables Included
 - 1 x Thunderbolt 3 cable - 2 m
- Localisation
- Input Voltage
- Power Consumption SDR (On mode)
 - 49 kWh/1000h
- Power Consumption HDR (On mode)
 - 54 kWh/1000h
Sustainability Information
- ENERGY STAR Certified
 - Limited warranty - 1 year , Technical support - phone consulting - 90 days
 - 10 °C
 - 35 °C
 - 5 - 95% (non-condensing)
