The contrast your eyes see between brightness and darkness is very challenging to reproduce in a display, leading to the development of High Dynamic Range (HDR). With breakthrough backlighting technology, Pro Display XDR takes brightness, contrast, and color to the high level. Far beyond HDR, it's Extreme Dynamic Range (XDR).
Show your truest colors
Pro Display XDR always gives you the truest representation of your work. A P3 wide color gamut provides a color palette capable of creating the most vibrant imagery. With true 10-bit color, Pro Display XDR can produce more than a billion colors with extreme accuracy. -
Superwide viewing angle
When multiple people review work together on a single screen, it's critical that everyone sees the same thing. While most pro desktop displays claim a wide viewing angle, in reality, color and image quality become distorted when seen off-axis. -
Retina 6K
Higher resolution means more than just a better-quality image. With a Retina 6K display, Pro Display XDR gives you nearly 40 percent more screen real estate than a 5K display. While most displays max out at around 150 pixels per inch (ppi), the Retina display has 218 ppi, providing astoundingly sharp and detailed imagery. It's a massive creative canvas that easily fits 4K content, your tools, and much more all in one screen. -
Reference modes
It's easy to adjust Pro Display XDR to match the requirements of HDR, HD, SD video, digital cinema, and broader uses such as photography, web development, design, and print. Just select a mode, and the display reconfigures itself to match a specified color space, white point, gamma, and brightness. And coming soon, you'll have the ability to create custom reference modes. -
True Tone
The lighting around you can affect the way you see onscreen colors. True Tone on Pro Display XDR uses a breakthrough dual ambient light sensor design - with a sensor on the front and another on the back - to better gage your overall lighting environment. This facilitates more exact adjustments to the color and intensity of your display, so you can have accurate viewing in all lighting conditions. -
Expertly calibrated
Pro Display XDR is optimized to more than meet the standards of creative professionals. Each of the display's 576 LEDs is also individually calibrated and has its light profile stored. -
A beautiful picture is only part of the story
Pro Display XDR is stunning every way you look at it. Its screen stretches edge to edge with just a 9 mm border, so your work takes center stage. The aluminum enclosure is just an inch thick and features an innovative lattice pattern that reduces weight and increases airflow. -
More air than metal
The lattice pattern machined into the aluminum has many advantages. It more than doubles the surface area exposed to air, facilitating additional airflow and acting as a heat sink. This allows for fast and quiet cooling, enabling Pro Display XDR to sustain an extreme level of brightness indefinitely. Inlet and exhaust vents work through this pattern to draw in cool air and eject hot air away from the system, limiting the potential for hot air to be reingested.
- Apple Pro Display XDR Standard glass - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 6016 x 3384 at 60 Hz
- Brightness
- 1600 cd/m²
- Contrast Ratio
- 1000000:1
- Colour Support
- 1.074 billion colours (10-bit)
- Input Connectors
- Thunderbolt 3
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50 - 60 Hz)
- Dimensions (WxDxH) - without stand
- 71.8 cm x 2.7 cm x 41.2 cm
- 7.48 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Designed For
- iMac (Early 2019); Mac Pro (Late 2019); MacBook Air with Retina display (Early 2020); MacBook Pro (Late 2019, Mid 2018, Mid 2019)
- Display Type
- Diagonal Size
- 32"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 218
- Brightness
- 1600 cd/m²
- Contrast Ratio
- 1000000:1
- Colour Support
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Aluminum enclosure, BFR/PVC-free, Mercury free, beryllium free, arsenic free, Retina display, fully laminated display, True Tone display, 10-bit Colour Depth, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), dual ambient light sensor
- 71.8 cm x 2.7 cm x 41.2 cm - without stand
- 7.48 kg
- Thunderbolt 3 / USB-C (power up to 95W) , 3 x USB-C
- Included Accessories
- Cleaning cloth
- Cables Included
- 1 x Thunderbolt 3 cable - 2 m
- Localisation
- Input Voltage
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 10 °C
- 35 °C
- 5 - 95% (non-condensing)
- Designed For
- Apple iMac (Early 2019) , Apple Mac Pro (Late 2019) , Apple MacBook Air with Retina display (Early 2020) , Apple MacBook Pro (Late 2019, Mid 2018, Mid 2019)
Apple Polishing Cloth | In Stock | £15.48 |
