The all-new Apple Pencil Pro adds even more magical capabilities to help bring your ideas to life like never before. Draw, paint and take notes with powerful new interactions that give you complete creative control effortlessly.
ADVANCED TOOLS
Apple Pencil Pro gives you ultimate creative control. Use gestures like Squeeze and Barrel Roll to access tools, change brushes and create strokes without missing a beat. Haptics allow you to feel shapes snap into place, and more. Use Apple Pencil hover on iPad Pro and iPad Air (M2) to preview your mark before you make it. And now, you can use Find My to locate your Apple Pencil Pro. -
EASY AND NATURAL
Apple Pencil Pro does it all with pixel-perfect precision, tilt and pressure sensitivity, and low latency. Featuring a flat edge, Apple Pencil Pro allows you to change tools with just a tap of your finger. Apple Pencil attaches, charges and pairs magnetically. -
TRANSFORMS IPAD INTO A CANVAS
Draw, sketch, colour, take notes and mark up documents. Use built-in apps like Notes and Freeform, or choose from over a million more apps available on the App Store.
- Apple Pencil Pro - active stylus - Bluetooth
- Active stylus
- Connectivity Technology
- Bluetooth
- 0.89 cm x 0.89 cm x 16.6 cm
- 19.15 g
- Movement Detection Technology
- Gyroscopic
- Magnetically attaches, pairs and charges, squeeze function, Apple pencil hover function, barrel roll function, Apple Find My compatible, double tap function, find my pen function, pressure sensitivity, tilt sensitive, rotation sensitive
- OS Required
- Apple iPadOS 17.5 or later
- 1-year warranty
- Designed For
- 11-inch iPad Air (M2, M3); 11-inch iPad Pro (M4); 13-inch iPad Air (M2, M3); 13-inch iPad Pro (M4); iPad mini (A17 Pro)
- Active stylus
- 0.89 cm
- 0.89 cm
- 16.6 cm
- 19.15 g
Input Device
- Interface
- Bluetooth
- Gyroscopic
- OS Required
- Limited warranty - 1 year
- Designed For
- Apple 11-inch iPad Air (M2, M3) , Apple 11-inch iPad Pro (M4) , Apple 13-inch iPad Air (M2, M3) , Apple 13-inch iPad Pro (M4) , Apple iPad mini (A17 Pro)
Apple Pencil Pro
