Apple Pencil Pro
Apple Pencil Pro
Quicklinx: HQ29WS00 Mfr#: MX2D3ZM/A
Device Type: Apple Pencil
Type: Stylus
Device Screen Size: [N/A]
Colour: White
More than 50 In Stock
£107.50 ex VAT
£129.00 inc VAT
The all-new Apple Pencil Pro adds even more magical capabilities to help bring your ideas to life like never before. Draw, paint and take notes with powerful new interactions that give you complete creative control effortlessly.
  • ADVANCED TOOLS
    Apple Pencil Pro gives you ultimate creative control. Use gestures like Squeeze and Barrel Roll to access tools, change brushes and create strokes without missing a beat. Haptics allow you to feel shapes snap into place, and more. Use Apple Pencil hover on iPad Pro and iPad Air (M2) to preview your mark before you make it. And now, you can use Find My to locate your Apple Pencil Pro.
  • EASY AND NATURAL
    Apple Pencil Pro does it all with pixel-perfect precision, tilt and pressure sensitivity, and low latency. Featuring a flat edge, Apple Pencil Pro allows you to change tools with just a tap of your finger. Apple Pencil attaches, charges and pairs magnetically.
  • TRANSFORMS IPAD INTO A CANVAS
    Draw, sketch, colour, take notes and mark up documents. Use built-in apps like Notes and Freeform, or choose from over a million more apps available on the App Store.
Apple Pencil Pro - active stylus - Bluetooth
Active stylus
Bluetooth
0.89 cm x 0.89 cm x 16.6 cm
19.15 g
Movement Detection Technology
Gyroscopic
Magnetically attaches, pairs and charges, squeeze function, Apple pencil hover function, barrel roll function, Apple Find My compatible, double tap function, find my pen function, pressure sensitivity, tilt sensitive, rotation sensitive
Apple iPadOS 17.5 or later
1-year warranty
11-inch iPad Air (M2, M3); 11-inch iPad Pro (M4); 13-inch iPad Air (M2, M3); 13-inch iPad Pro (M4); iPad mini (A17 Pro)
Active stylus
0.89 cm
0.89 cm
16.6 cm
19.15 g
Input Device
Bluetooth
Gyroscopic
Limited warranty - 1 year
Apple 11-inch iPad Air M2 Wi-Fi, M2 Wi-Fi + Cellular, M3 Wi-Fi, M3 Wi-Fi + Cellular , Apple 11-inch iPad Pro M4 Wi-Fi, M4 Wi-Fi + Cellular , Apple 13-inch iPad Air M2 Wi-Fi, M2 Wi-Fi + Cellular, M3 Wi-Fi, M3 Wi-Fi + Cellular , Apple 13-inch iPad Pro M4 Wi-Fi, M4 Wi-Fi + Cellular , Apple iPad mini A17 Pro Wi-Fi, A17 Pro Wi-Fi + Cellular
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HQ29 050512
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £71.59
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Stylus
Colour: White
Brand: Apple
Stock Status: Used Stock
