Apple Pencil (1st Generation)
Quicklinx: H17XWS00 Mfr#: MQLY3ZM/A
Device Type: iPad Mini, iPad, iPad Air, iPad Pro
Type: Stylus
Device Screen Size: [N/A]
Colour: White
Select:
34 In Stock
£90.84 ex VAT
£109.00 inc VAT
Express delivery Order within the next 9 hours for delivery on Monday
Apple Pencil expands the power of iPad and opens up new creative possibilities. It’s sensitive to pressure and tilt so you can easily vary line weight, create subtle shading and produce a wide range of artistic effects — just like a conventional pencil, but with pixel-perfect precision.
What’s in the Box
  • Apple Pencil
  • Lightning adapter
  • Extra tip
  • USB-C to Apple Pencil Adapter (required to pair and charge 10th-generation iPad)
Tech Specs
  • Length: 175.7 mm (6.92 inches) measured from tip to cap
  • Diameter: 8.9 mm (0.35 inches)
  • Weight: 20.7 grams (0.73 ounces)
  • Connections - Bluetooth
  • Lightning connector
  • Magnetically attached cap
Compatibility
  • iPad Pro 12.9-inch (2nd generation)
  • iPad Pro 12.9-inch (1st generation)
  • iPad Pro 10.5-inch
  • iPad Pro 9.7-inch
  • iPad Air (3rd generation)
  • iPad (10th generation)
  • iPad (9th generation)
  • iPad (8th generation)
  • iPad (7th generation)
  • iPad (6th generation) iPad mini (5th generation)
  • Seamless connectivity
    With its Bluetooth wireless interface, the Apple Pencil ensures a stable connection to your tablet, offering a smooth and uninterrupted drawing experience.
  • Versatile charging options
    The inclusion of both USB-C to Lightning and Lightning adapters provides flexible charging solutions, ensuring your Apple Pencil is always ready for use.
  • Precision design
    Crafted for accuracy, the fine pen tip of the Apple Pencil allows for detailed work on your tablet, from note-taking to graphic design.
Apple Pencil 1st Generation - stylus for tablet
Stylus
Intended For
Tablet
Wireless Interface
Bluetooth
Package Content
Stylus, pen tip, lightning adapter, USB-C to Lightning adapter
0.89 cm x 0.89 cm
Length
17.57 cm
20.7 g
1-year warranty
9.7-inch iPad (6th gen); 10.2-inch iPad (7th gen, 8th gen, 9th gen); 10.5-inch iPad Air; 9.7-inch iPad Pro; 10.5-inch iPad Pro; 12.9-inch iPad Pro (1st gen, 2nd gen); iPad mini 5
Stylus
Intended For
Tablet
Wireless Interface
Bluetooth
Package Content
0.89 cm
0.89 cm
Length
17.57 cm
20.7 g
Apple Lightning - Lightning
Limited warranty - 1 year
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (6th generation) , Apple 9.7-inch iPad Pro , Apple iPad mini 5
Device Type: iPad
Device Type: iPad Air
Device Type: iPad Pro
Type: Stylus
Colour: White
Brand: Apple
