Apple Micro DVI to VGA Adapter
Quicklinx: 70PKWS00 Mfr#: MB203G/A
The Apple Micro-DVI to VGA Adapter was designed specifically to fit the slim profile of MacBook Air. Connect the adapter to the Mini-DVI port of your MacBook Air and the VGA end of the adapter to an external VGA monitor or projector. You can use this cable in both video mirroring and extended desktop modes.
Apple VGA adapter
VGA adapter
Connector
Micro-DVI
Connector (Second End)
HD-15 (VGA)
VGA adapter
Connector
Apple micro-DVI
15 pin HD D-Sub (HD-15)
