The 60 watt MagSafe Power adapter features a magnetic DC connector that ensures your power cable will disconnect if it experiences undue strain and helps prevent fraying or weakening of the cables over time. In addition, the magnetic DC helps guide the plug into the system for a quick and secure connection.
When the connection is secure, an LED located at the head of the DC connector will light up; amber light lets you know that your portable is charging, while a green light tells you that you have a full charge. An AC lead is provided with the adapter for maximum lead length, while the AC wall adapter (also provided) gives users an even easier and more compact way to travel.
Designed to be the perfect traveling companion, the adapter has a clever design that allows the DC cable to be wound neatly around itself for easy cable storage. This power adapter recharges the lithium polymer battery while the system is off, on, or in sleep mode.
- Apple MagSafe - power adapter - 60 Watt
- Power adapter - external
- Localisation
- English / United Kingdom
- Power Capacity
- 60 Watt
- Localisation
- Power Capacity
- 60 Watt
- Cables Included
- Power cable - integrated
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
9G3D 050973 Condition: Customer return - item has been used but is in excellent condition |
£42.35 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
