Apple Magsafe Power Adapter - 45W (MacBook Air)
Quicklinx: 9LQ8WS00 Mfr#: MC747B/B
The 45-watt MagSafe power adapter for MacBook Air features a magnetic DC connector that ensures your power cable will disconnect if it experiences undue strain and helps prevent fraying or weakening of the cables over time. In addition, the magnetic DC helps guide the plug into the system for a quick and secure connection.
When the connection is secure, an LED located at the head of the DC connector will light; an amber light lets you know that your portable is charging, while a green light tells you that you have a full charge.
Redesigned specifically for MacBook Air, the adapter is the perfect traveling companion. It has a clever design which allows the DC cable to be wound neatly around itself for easy cable storage.
This power adapter recharges the lithium polymer battery while the system is off, on, or in sleep mode. It also powers the system if you choose to operate without a battery.
Apple MagSafe - power adapter - 45 Watt
Power adapter - external
United Kingdom
Power Capacity
45 Watt
MacBook Air 11" (Mid 2011, Late 2010); MacBook Air 13" (Mid 2011, Late 2010)
United Kingdom
Power Capacity
45 Watt
Power cable - integrated
LED indicators
