Apple MagSafe Duo Charger - Wireless charging mat
Quicklinx: GHP6WS00 Mfr#: MHXF3ZM/A
Device Type: MagSafe
Type: Wireless Charging
Product Range: Apple
Product Model: MagSafe Duo Charger
£90.84 ex VAT
£109.00 inc VAT
The MagSafe Duo Charger conveniently charges your compatible iPhone, Apple Watch, Wireless Charging Case for AirPods, and other Qi-certified devices. Just place your devices on the charger and a steady, efficient charge begins on contact. The charger folds together neatly so you can easily take it with you wherever you go.
Apple MagSafe Duo Charger wireless charging mat - magnetic
Output Connector Type
Total 2: magnetic
Wireless Charging
Wireless Charging Standards
Qi
Cables
USB-C to Lightning cable - 1 m
1-year warranty
Mobile phone, smart watch, wireless earphones
Input Connectors
24 pin USB-C
Output connectors
Total 2: magnetic
Wireless Charging
Qi
Limited warranty - 1 year
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: GHP6 047947
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £49.12
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Apple
Stock Status: Used Stock
