Apple MagSafe Charger
Quicklinx: G0XCWS00 Mfr#: MHXH3ZM/A
Overview
The MagSafe Charger makes wireless charging a snap. The perfectly aligned magnets attach to your iPhone 13, iPhone 13 Pro, iPhone 12 and iPhone 12 Pro, and provide faster wireless charging up to 15W.
The MagSafe Charger maintains compatibility with Qi charging, so it can be used to wirelessly charge your iPhone 8 or later, as well as AirPods models with a wireless charging case, as you would with any Qi-certified charger.
The magnetic alignment experience only applies to iPhone 13, iPhone 13 Pro, iPhone 12 and iPhone 12 Pro models.
Recommended: 20W USB-C Power Adapter (sold separately)
What’s in the Box
  • MagSafe Charger
  • USB-C integrated cable (1 m)
  • Effortless charging
    Experience the convenience of wireless charging with the Apple MagSafe Charger, designed specifically for cellular phones. Its magnetic alignment ensures your device is perfectly positioned for optimal charging every time.
  • Universal compatibility
    The MagSafe Charger is equipped with Qi wireless charging standards, making it compatible with a wide range of devices. Enjoy the freedom of charging without the need for cables.
  • Powerful performance
    With a power output of 15 W, this wireless charging mat provides fast and efficient charging, ensuring your device is ready to go when you are.
Apple MagSafe Charger wireless charging mat - magnetic - 15 Watt
Wireless charging mat
Mobile phone
Output Connector Type
Magnetic
Wireless Charging
Wireless Charging Standards
Qi
Power Provided
15 Watt
Cables
USB-C cable - 1 m
1-year warranty
Mobile phone
Input Connectors
24 pin USB-C
Output connectors
Magnetic
Power Provided
15 Watt
Wireless Charging
Qi
USB-C cable - 1 m
Limited warranty - 1 year
